Results 1 to 7 of 7
Thread: passanger window question
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    Default passanger window question
    hey all
    im asking this first before i inspect it as my windows are still covered in paper for the last of the paint job that needs doing...
    only the passanger window does this, u wind it up and before it hits the top it goes on a slant forward and i have to hold it back with my hand just to fully wind it up...
    anybody had this issue ?
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    either your baily channel is bent near the top and allows the window too pivot
    the rubber is stuffed allowing the same
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
    calais24/7's Avatar
    calais24/7 is offline Mucca Mad Boys
    VS Calais II 5L, 98 rodeo v6
    Jul 2009
    mate have the same problem, drivers one goes up 70% and then the front dips in and you have to oull it to get it level and it sorta jumps up when you pull it then its fine. no idea what it might be. and im pretty sure my rubber seals are a ok
    Goon's Avatar
    Feb 2006
    GC. QLD
    Quote Originally Posted by VL Berlina 5speed View Post
    cheers bro ill inspect it when i can..
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    it is probably your window regulator, the regulator arms and support arm are held together by a spotweld which can break and allow movement, this will happen as normal wear and tear or if some ar$ehole has tried to force the window down. also the pivot point on the regulator can develop movement over time the same as above.
    replace the window regulator.
    Nobody wants to play with me
    detox_nath83's Avatar
    detox_nath83 is online now Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    i fixed a few like this but on vn commos...
    its the scissor looking channels in the door where the nylon lugs sit in and slide as the window is lowered or raised.. the nylon lugs gets warn causing it to twist slightly and drop the window. inspect/replace the nylon runners and regrease channel..
    goodluck bud
    Goon's Avatar
    Feb 2006
    GC. QLD
    cheers guys for the extra tips, ill get it fixed
  1. VX II Passanger Airbag Installation
    By Cica9 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-11-2010, 05:04 PM
  2. [VIC] VL Headlight passanger side
    By westbad in forum Parts And Other Items For Sale
    Last Post: 04-08-2009, 11:38 PM
  3. Replies: 4
    Last Post: 28-03-2009, 06:37 PM
  4. removed passanger seat and.....
    By eclipz in forum VY Holden Commodore (2002 - 2004)
    Last Post: 20-10-2008, 04:02 PM
  5. Coax Cable under passanger seat,
    By Terence in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-01-2005, 06:04 PM
