Results 1 to 14 of 14
Thread: annoying problem
    vl commodore
    May 2009
    Default annoying problem
    Guys this problem is really starting to get the better of me. i will start my vl and it will run perfectly, now it could be 30secs later or 5 mins later it will start popping and carrying on then may either drop to about 200rpm and continue to run or it will cut out completely. i have tried 2 afm 4 cas an o2 sensor and checked for any vacuum or air leaks and cant nail the problem. when i try to start it after it cuts out it wont start just crank and not fire. could it be the coil? its had a full rebuild, new plugs new leads, thermostat basically everything is new.
    something i noticed when i last changed the cas was the little round plate in the dizzy had been scraping on the cas and had marks in it from where it was shaving it off, found little shavings everywhere. its together correctly so i can work out why this would be happening.
    I read someone else's post and someone said the brake booster could cause this problem, im yet to bleed my brakes after rebuilding the front end and have no pedal, could this have anything to do with it? As you can see im scratching for answers? Any help would be much appreciated!!!!
    bf xr6 daily, vl project, wb ute project
    Aug 2008
    QLD
    I had something very similar happen recently and it turned out to be the injectors, worth a look if you're stumped for ideas...
    Holdfast is offline Donating Member
    VE & VL
    Jan 2005
    Mate have you checked the codes on the Electronic Combustion Control System (ECCS commonly know as the computer)?
    May be the ECCS could be buggered?
    Sometimes the Power Transistor can be stuffed as-well.
    vl commodore
    May 2009
    I'll try disconnecting them one by one to see if any of them arnt working but it doesn't really run well long enough to do that. not sure how to test injectors the way it is currently running but thanks anyway bloke.
    vl commodore
    May 2009
    holdfast, i tried that and got no real sense out of it i got about 5 codes then tried resetting and got same again. this current problem is only sense i rebuilt so i wouldn't think it was the eccs itself. the only reason i rebuilt was because the bloke i brought it off was running dam water through it and it was choked up kept over heating. but i have a spare eccs so i will try that. thanx
    VE & VL
    Jan 2005
    Quote Originally Posted by cjwau View Post
    Is the stainless steel slotted plate with the 360 slots in it damaged?
    Its easy to damage the plate and it shouldn't rub.
    Any dust or scrapings will send a wrong or distorted signal back to the ECCS mate.
    VE & VL
    Jan 2005
    I wouldn't try the ECCS yet mate, check the plate and also check you haven't got a very slightly bent distributor shaft. Did you put a new bearing in the distributor?
    vl commodore
    May 2009
    yeah the plate is damaged i was pretty sure from the start that the problem was in the dizzy. it actually crossed my mind the shaft might be bent. brought a secondhand dizzy that came out of a working motor ill pick it up this week and put it straight in and see what happens. thanx mate i reckon theat will be the problem.
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    if that plate is damaged that is ALMOST certainly your problem.
    other things to consider is the power transistor ( little thing with plug attached)on the distributor.
    brake booster will cause the problem IF it has a vacuum leak and belive it or not low trans fluid will also cause similar problems.
    next would be engine emmision controls eg, aac valve.
    Nobody wants to play with me
    detox_nath83's Avatar
    detox_nath83 is online now Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    I had same problem a few years back...turned out to be inertia pump(Intank Fuel pump) failing/on its way out.
    As for your metal disk it would clearly be that causing your probs as the CAS is diode controlled sensors reading the tiny slits in the disk telling the engine when to fire.
    vl commodore
    May 2009
    Default Thanx all
    thanx guys i was pretty sure that the plate would be the problem. had a spare in the shed it was damaged in the center from removal but had no marks around the outside like the one in the dizzy currently. thought it was a bit odd, question is why is it happening. replacing that dizzy with another one tomorrow ill c what happens!
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    vl commodore
    May 2009
    Default Thanx all
    thanx to all you guys that posted thier thoughts. I picked up the new dizzy threw it in and away it went first go. Purrs like a kitten with a throaty cough.
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    check it timing could be running retarted.
  1. Annoying Problem.
    By Torniquet in forum Car Audio
    Last Post: 02-03-2009, 10:13 PM
  2. An annoying problem
    By HoldenManDan in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-01-2007, 11:08 AM
  3. Very Annoying problem!!
    By fitzy2005 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-11-2006, 06:55 PM
  4. Very annoying problem
    By Philthy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-11-2006, 04:22 PM
  5. Annoying Problem!
    By ChRiDDa in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-02-2004, 12:50 PM
