Results 1 to 8 of 8
Thread: coolant level in radiator
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    Default coolant level in radiator
    ive been driving my car every day this week and ive been keeping my eye on everything
    one thing ive noticed is that after every drive and once the car has cooled down the radiator level has dropped to about a cm or so bellow full
    its always droping to the same level too
    i have my over flow bottle mounted but its lower then they system, next too the front bar reo bolts on the rail
    ive bleed the system with the two bolts on the manifold twice since with a funnel and pipe on the over flow pipe,
    and its flows out air free
    the oil cap is not creamy, dip stick is fine, nothing out exhause, its running fine
    should i be worrying?
    could this be because my over flow bottle is too low and wont syphine back up?
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
    VR Berlina S2
    Aug 2009
    I think your right.
    I really don't think a radiator would have the ability to suck coolant up to that level, but sure it would over flow to it.
    selling vp calais wheels with 97% rubber hardly used!
    VN WAGON
    Sep 2007
    Oct 2005
    Quote Originally Posted by BONSVR View Post
    I think your right.
    well i think it could be fine as many new cars run coolant bottles lower
    few toyotas do
    but not sure if the system is designed to be like that
    Quote Originally Posted by meanvn View Post
    its just the pressure making it move up and down.
    what in the radiator
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    detox_nath83's Avatar
    detox_nath83 is online now Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    Gday 5Speed have you go a decent seal at your overflow bottle... rad creates vacuum upon cooling and sucks the overflow back in to rad. possible could be losing vacuum and not sucking coolant back into rad
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    i guess u could tell if ur overflows bottle is working by the amount of fluid in it??
    maybe the water could be evaporating, it is hotter times then back in the 80's..
    Holdfast is offline Donating Member
    VE & VL
    Jan 2005
    Quote Originally Posted by VL Berlina 5speed View Post
    Mate, could you check the radiator cap?
    Sometimes an older cap will allow coolant loss! Probably worth a look.
    Oct 2005
    well the cooling system is compeltly brand new
    every pipe is new and radiator is new, radiator cap is new,
    but think ive found the problem
    have green dryed coolant that seeps out of the top radiator hose part of the manifold
    where it bolts too the head, so obviously didnt seal 100%
    so ill have to take the manifold off eventually and try again
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
LinkBacks (?)
  1. Coolant Level Sensor/Warning Light
    By mulligan-can in forum VL Holden Commodore (1986 - 1988)
    Last Post: 10-06-2008, 12:20 PM
  2. radiator.. coolant... etc...
    By TWOJZ in forum VL Holden Commodore (1986 - 1988)
    Last Post: 28-04-2008, 07:39 PM
  3. Coolant level
    By WGN Berlina in forum VY Holden Commodore (2002 - 2004)
    Last Post: 18-03-2008, 10:23 PM
  4. Coolant Level
    By Stretcher Bearer in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-01-2007, 08:31 PM
  5. Radiator Coolant Level...
    By Hairy Eater in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-12-2005, 08:54 PM
