Results 1 to 4 of 4
Thread: Speedometer not working?
    VL Turbo
    Oct 2009
    Default Speedometer not working?
    Hey Guys,
    Just picked up a VL yesterday with a RB20 Motor in it runs all good etc. just the Speedometer not working and the RPM is it just a missing wire?
    The Bloke said its since the conversion to the RB20.
    So what should I do now?
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    the speedo on a vl is mecahnical
    a cable runs to the side of the gear box and screws in same with the cluster
    look under the car on the drivers side of the gear box, there should be cable which screws into the side of the box
    runs up the fire wall and into the cabin near the brake booster
    if thats connected check the inside part behind the cluster, might came dislodged
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
    VL Turbo
    Oct 2009
    have checked it today and everything is hooked up but still not working
    what else could it be?
    '96 VS Commodore Equipe Sedan
    Apr 2009
    It could be a couple of things really.
    There is a gear on the end of the cable that meshes with a gear on the output shaft of the gearbox. These are both made of plastic or similar material. If either one strips, then the speedo will not work (obviously). If you find that they are not stripped then it could be a case of the output shaft gear slipping or has slipped down the shaft and is not in contact with the gear on the cable.
    The cable gear is easy to replace as it is just held on with a roll pin (from memory anyway). The Gear on the output shaft is a bit more involved. To replace it, you have to pull the rear gearbox extension housing off to get to the gear. You will lose a lot of gearbox oil in the process so just be warned. It is a good practice to replace the rear gearbox seal when you do this job as well.
    If you want to see if the speedo head is working, remove the cable from the gearbox, take the plastic gear off and attach the cable to a cordless or an electric drill and wind it up. have someone watch to see if the speedo moves. If it does move then your problem is in the gearbox.
    I hope this helps
LinkBacks (?)
  1. Speedometer not working
    By Hardstylin in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-06-2009, 07:22 PM
  2. speedometer
    By macatac in forum Electrical Wiring / Questions
    Last Post: 21-08-2008, 09:06 AM
  3. VN Speedometer
    By snoogy_beef in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-06-2006, 01:06 AM
  4. Speedometer Not Working
    By Aussie_Watto in forum VL Holden Commodore (1986 - 1988)
    Last Post: 17-08-2005, 06:32 PM
  5. VR speed alert and speedometer not working
    By johnnyk in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-08-2005, 03:31 AM
