I have a Vl Calais and I got a problem with the engine (natural rb30). It turns over but wont fire. I've put in new crank angles, fuel pressure regulator, spark plugs, injectors, fuel pump etc. to try solve problem but no luck so far. Any ideas on what it could be?
Cheers, Anthony
coil?......
have you checked for injector pulse ? did you install the crank angle sensor correctly ??? keeping checking could be something simple like a bad earth or dislodge pin inside a wiring connector etc etc ?
Battery needs charging, turns over but not enough juice to get her to fire up??
search other threads regarding this issue, it has been covered numerous amount of times and all we do is repeat and repeat whats to look for.
power trasistor on dizzy not switching possibly. check plugs on CAS and COIL under the rubber boot not just the plug
look where spade conectors are crimped in back of it,
its not a big problem
