Results 1 to 19 of 19
Thread: vl wont start
    vl
    Oct 2009
    Exclamation vl wont start
    hey im kinda new here and i got my vl a while ago and it hasn't started since i got it and when i turn the key i just hear a single click or tick and nothing happens is this the starter motor? or does it have some sort of immobilizer on it? idk what im on about i just need help please
    vl
    Oct 2009
    Nackerz's Avatar
    Nackerz is offline Rollin
    2 n/a vl's 1 twin turbo vl vn ss vy sv8
    Jul 2009
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    Nackerz's Avatar
    Jul 2009
    premium's Avatar
    premium is offline P-Plater
    1988 VL Berlina, 1985 VK SL
    Sep 2009
    Williamstown, VIC
    typical of a dead battery, try jumping it.
    Quote Originally Posted by premium View Post
    high-performance sunroof?
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    if it doesnt jump it , its the starter motor... rock the car back n forth abit in gear or N and give it a turn over back in N.. it might start one last time...
    overall id say the starter motor if the batterys still good.
    vk.jonno's Avatar
    vk.jonno is offline :):):)
    Vk commodore, hq one tonner, hj ute,
    Nov 2009
    south east
    i had a simmiliar problem with my car. it wont start on its on but it will start if i connect it to the 4wd
    so try jump starting it
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    vl
    Oct 2009
    sorry havnt been able to get on the net....it makes a single click when i turn the key on sorry for not bein here to reply
    vl
    Oct 2009
    its not the battery or the starter it makes a single click when i turn the key is it like an immobilizer thats cutting the power to it?
    VK Calais 308
    Sep 2008
    check the relay to the starter or the connections to it, I had a similar problem i just jump started it and it was sweet. My VK did a single click and yea. Immobilizer... don't know, most people when wiring just hook it up to the ignition wire in the steering column. So i wouldn't make a click noise, wouldn't make a noise full stop. I'm guessing that if the battery is full charged and the starter works. then, check the relay. that Click your hearing could be from that.
    VL Berlina turbo, VL SL turbo ~STOLEN~
    Aug 2007
    Newcasstle
    Your starters ****ed. Get someone to have the key turned while you hit the starter motor with a stick or pole. I bet it will start. Mine is the same.
    Nackerz's Avatar
    Jul 2009
  15. #15
    1986 vl sl
    Oct 2011
    brisbane
    my vl didnt start for 2 years when i bought it, check all relays and your connections, then have a look at your engine ground. might be a good idea to change the battery also.
  16. #16
    1986 vl sl
    Oct 2011
    brisbane
    87RB30VL's Avatar
    87RB30VL is offline Your mum's new boyfriend
    87' VL SL
    Feb 2011
    brisbane
    I took my battery leads off because I wanted to crimp some proper ends onto my wires for my amp etc, and after putting it all back on, sometimes when I turn my key the car just does 1 single click, then I have to pop the hood and wiggle my negative terminal a bit, then the car starts, so try doing that as well.
    |8|7|R|B|3|0|V|L|
  18. #18
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
  19. #19
    87RB30VL's Avatar
    87' VL SL
    Feb 2011
    brisbane
    Yeah I guess if I can wiggle the negative one it's way too loose lol
    |8|7|R|B|3|0|V|L|
  1. wont start
    By pooly.09 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-08-2009, 05:48 PM
  2. Car wont start. Grr
    By joe_rolls_commo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-08-2009, 03:03 PM
  3. VP V8 Wont Start
    By E_ri_k in forum Electrical Wiring / Questions
    Last Post: 04-03-2009, 03:57 PM
  4. help VR wont start
    By spraypaintergm in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-04-2007, 10:14 AM
  5. VN wont start
    By stocky in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-02-2007, 11:59 AM
