Results 1 to 7 of 7
Thread: how do i fix the aircon/vent controls
    Jezza's Avatar
    Jezza is offline Ecotec Just Kicked In!
    VYII Acclaim
    Apr 2009
    South Australia
    Default how do i fix the aircon/vent controls
    well as its gonna be 36 in adelaide on sunday im thinking it would be good if i finally got around to fixing car vent/aircon control device thing and i was wondering if anyone knew how to get behind the unit and how i go about removing the glove box to get to it because at the moment i only get the floor (on aircon to the face XD ) or the dimister (for non aircon setting) settings and the others dont work and my mechanic said its probably the vacuum hose so i need to get to the back to look at it
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    ok man
    unscrew the one screw retaining the control panel(left of radio under vent) then behind it(passanger side) unhook the heater box control rod and you will be able to pull it out enough for you to look at and fix the vac hoses. the switches can be a bit worm so c how u go.
    if the tags with the numbers have come off the hoses just trial and error the vac lines till they work properly. as in feet setting does not go to face vents, demister go to feet etc etc.. its not that hard to work out. i had to do it.
    goodluck man let us know
    Jezza's Avatar
    VYII Acclaim
    Apr 2009
    South Australia
    i know about the screw under the vent but there is another one? where behind it?
    VL Wagon 5 Speed
    Sep 2009
    there shouldn't be, you should be able to just wriggle the controls out, then suss out the nipples and hoses. nathan do you know how the system works? what does the vacuum actuator do?
    Jezza's Avatar
    VYII Acclaim
    Apr 2009
    South Australia
    i have fixed it and it was a very simple thing and i have working aircon to
    VL Wagon 5 Speed
    Sep 2009
    top stuff, i fixed mine today so i have dimister! took a bit of trial and error coz the numbers are gone!
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    nice fellas nice.... its not too hard....
    people feel it still tight after taking screw out but it the heater box rod which holds it in.... unhook and away u go...
    :P go to hear all working
  1. VY heater , aircon controls
    By putz in forum VY Holden Commodore (2002 - 2004)
    Last Post: 26-04-2009, 11:33 AM
  2. Aircon vent controller changing mode
    By victor junior in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-03-2008, 03:40 PM
  3. Removing aircon controls, mode switch, light switch
    By wrx884 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-03-2006, 10:53 AM
  4. aircon controls question [84 vk berlina]
    By unregistered in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 11-01-2006, 11:05 PM
  5. VP aircon controls
    By Pico in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-08-2005, 02:20 PM
