Results 1 to 9 of 9
Thread: Air conditioner Repair
    2005 VZ SV6
    Aug 2009
    Default Air conditioner Repair
    Hi guys.
    Just wondering, when i try to turn on my air con, it doesnt even look like working lol... all i hear is a sound that i can only describe as gas escaping? It sort of sounds like a hissing sounds if that makes sense... I'm just wondering if anyone could tell me what the problem might be ? and what i need to fix it ?
    Summer is coming... lol and i don't want to fry.
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Stop bagging him, he needs all those speakers to drown out the bullshit he dribbles.....
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    would be a vacuum hose from behind the unit has come off
    undo 1 screw retaining air control panel under left face vent in centre
    unhook heater box rod and unit should come out
    2005 VZ SV6
    Aug 2009
    ok nath, i took the panel off, but i cant really see anything resembling a hose, but i do see a lot of wires lol. any tips as to what im looking for here? and also if i find what i need to do ? and i should say that the panel wont really come off very far to the point that i can sorta get behind it... lol
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    if u unplug the connector you will be able to pull it out a bit to get behind it,..
    there is a vacuum disk looking thing with all pipes coming off it about and inch long. then you will have about 6 vac hoses coming to these pipes (one vac feed and the others goto vacuum controllers inside your air plumbing for opening and closing flaps.)
    these vac hoses control all your vents as in directing air to say feet/ face /demister etc etc..
    goodluck man
    2005 VZ SV6
    Aug 2009
    lol, cheers.. im thinking i will need it haha.
    Jezza's Avatar
    Jezza is offline Ecotec Just Kicked In!
    VYII Acclaim
    Apr 2009
    South Australia
    it could be broken to because that unit was a common thing to break like mine is and i want to get aircon working since it was 37 today and its over 35 till at least sunday and i have bought a working unit but i just need to install it
    2005 VZ SV6
    Aug 2009
    haha yeah i know.. i really don't want to roast under this sun !
    vl executive
    Jul 2010
    tumut
    can someone please show me a diagram of what the hoses plug into as my hoses have numbers but my valves dont so i cant figure it out
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    it should be moulded on to the valves at the base on the control unit.
    Mine had the hose numbers flaking off so it was trial and error untill it worked right,,
    Have your fan going and the main vacuum line in(longest Barb on the unit.) .... then just attach one hose at a time and use the slider on the device to determine what hose is what and move it to the right position...
    u will work it out...
    Goodluck
  1. Air Conditioner
    By CLMCKENZIE in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-04-2006, 02:33 AM
  2. Air Conditioner
    Last Post: 23-11-2005, 01:22 PM
  3. VS air conditioner fan
    By lonesurvivor in forum Electrical Wiring / Questions
    Last Post: 21-03-2005, 11:17 AM
  4. Air Conditioner
    By blue alliance in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-01-2005, 07:53 PM
  5. Vn Air Conditioner
    By arty in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-12-2003, 10:42 PM
