Page 1 of 2 12 LastLast
Results 1 to 25 of 30
Thread: Deaccelarate backfire
    calais24/7's Avatar
    calais24/7 is offline Mucca Mad Boys
    VS Calais II 5L, 98 rodeo v6
    Jul 2009
    Default Deaccelarate backfire
    Is there anything you can do to stop that sh**y backfire to stop when you back off the go pedal and slow down ?
    Nackerz's Avatar
    Nackerz is offline Rollin
    2 n/a vl's 1 twin turbo vl vn ss vy sv8
    Jul 2009
    VL Berlina turbo, VL SL turbo ~STOLEN~
    Aug 2007
    Newcasstle
    Quote Originally Posted by vlcommodore01 View Post
    How big is your exhaust and does it have a rear muffler or just a pipe. When i got my fagwag it had a 2.5" exhaust cut before the diff and used to backfire and pop on deacelleration. Then i had a 2.5" pipe and rear muffler welded up. Pretty quiet exhaust now with a nice tone and still quietly pops on deaccell... Think its to do with the size of the pipe....
    I drive a VL Commodore's Avatar
    I drive a VL Commodore is offline I drive a Skyline, too.
    VL Commodore Poverty Pack
    Jan 2009
    Adelaide, South Australia
    Get your injectors leak- and flow- tested. If it's properly backfiring it means fuel is getting into the cylinders when it shouldn't be.
    If I recall correctly RB30's shut down fuel completely (or almost) on 0% throttle over a certain RPM. In my 5 speed Skyline it was about 3,000rpm ish. So it shouldn't be backfiring.
    It's as if society expects me to act like a cockmongler when I'm driving the Commodore. People always look at me weird when I go the speed limit, or indicate for more than 2.5 clicks or accelerate moderately off the lights... wtf
    calais24/7's Avatar
    Jul 2009
    Quote Originally Posted by I drive a VL Commodore View Post
    How much roughly is a leak and flow test? Also i dont have a stock exhaust its 2.5"
    VXII
    Nov 2009
    An exhaust backfire on deceleration is usually due to an air leak in the pipe somewhere up near the engine - possibly the manifold gasket at the head or flange with the rest of the system. It sucks oxygen into the pipe when there's a slight vacuum on deceleration and allows any incompletely burnt gasses in the pipe to burn.
    VP Executive R-spec
    Jan 2005
    More timing during deceleration fixes it. So perhaps your timing isn't quite right
    2005 VZ SV6
    Aug 2009
    Just out of interest, coz im new to the whole scene, what exactly do you mean by "shutting down fuel completely"
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Stop bagging him, he needs all those speakers to drown out the bullshit he dribbles.....
    VL Wagon 5 Speed
    Sep 2009
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    VL Wagon 5 Speed
    Sep 2009
    and what should one do if it's outside specs? isnt it possible to spray something on the hoses and see bubbles? or am i mistaken? cheers
    2005 VZ SV6
    Aug 2009
    If you put soapy water on your lines, if theres any leaks, you'll see bubbles start to form.
    VT spac super6
    Nov 2008
    Riverton sa
    Or, check/ listen for exhaust leaks in the front section of the exhaust.. this will cause it
    calais24/7's Avatar
    Jul 2009
    Alright cheers for all that, also could it be something simple like a foul plug? I just changed the fuel filter and still not it. I'm going to change the plugs and see if that helps
  15. #15
    calais24/7's Avatar
    Jul 2009
    Not spark plugs, not leads, not fuel filter, also it is a bit sluggish at the moment and its shitting me. I know it should have more poke then what it does, any more ideas. It has to be something with mixtures or fuel, thats my guess anyways
  16. #16
    vb sle
    Jan 2009
    adelaide
  17. #17
    VP Executive R-spec
    Jan 2005
    Quote Originally Posted by greenfoam View Post
    I think this guy was right
  18. #18
    Calaber's Avatar
    Calaber is offline Nil Bastardo Carborundum
    CG Captiva SX
    Nov 2007
    Lower Hunter Region NSW
    I'll go with Mooseman. Leaks in the exhaust towards the front of the system will cause backfiring for exactly the reasons he says. When you back off, the amount of unburnt fuel fed into the pipe only needs a bit of oxygen to set it off and, when you back off, there is a vacuum created within the pipe which draws air in through any leaks that exist. The leak needs to be towards the front of the system because of the heat present there which is sufficient to assist combustion.
  19. #19
    calais24/7's Avatar
    Jul 2009
    Alrighty ill look into the timing and see if i have issues, could that be the source of the problem and causing it to be sluggish aswell? Also calaber how could i check for a leak like that?
    Cheers guys
  20. #20
    calais24/7's Avatar
    Jul 2009
    Found out my AFM is cactus so this should be the the cuase to the problems, now to track down a working afm asap
  21. #21
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
  22. #22
    calais24/7's Avatar
    Jul 2009
    Will do man espicially if the have those adjustable screws but do you reckon it would be making it sluggish and backfire?
  23. #23
    Calaber's Avatar
    CG Captiva SX
    Nov 2007
    Quote Originally Posted by PMS-247 View Post
    Cheers guys
    The leak can be very slight. Simplest way is to put the front of the car on ramps and start the engine, leaving it idling. Crawl under with a small piece of light paper like tissue and run it carefully along the exhaust, without actually touching the pipes. If you can't hear the leak, the gases may move the tissue paper as it passes over them, but usually, up close, you will hear the leak. Most likely place is any pipe joints, starting with the manifold and working back. Also, look for point along the pipe where it has scraped when passing over speed humps or rocks. Sometimes, this happens so often the pipe can actually wear through. Obvious points to look for would be the lowest point in the system.
  24. #24
    VXII
    Nov 2009
    Get someone to put their hand over the exhaust pipe at the back (with a rag if they have lady hands) and listen for the hiss while you're underneath. You'll hear it pretty quickly.
    Don't let too much pressure build up though, or you could blow out a rust hole in your muffler or something.
  25. #25
    Calaber's Avatar
    CG Captiva SX
    Nov 2007
    Quote Originally Posted by moose man View Post
    Agreed. Easier and more effective than my method.
  1. Backfire help?
    By pauagirl in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-01-2009, 08:54 PM
  2. Mad ass crackly backfire
    By SV6er in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 29-10-2008, 07:13 PM
  3. Backfire
    By vsstock in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-07-2008, 05:21 PM
  4. gas backfire
    By johnvtls1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-11-2007, 12:07 PM
  5. LPG backfire when starting car (and possible fix)
    By Gravy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-04-2005, 08:36 PM
