Results 1 to 5 of 5
Thread: What is up with my VL?
    1988 Holden Vl Commy
    May 2009
    Wellington
    Default What is up with my VL?
    Hi my vl runs and drives sweet. Only has done 143k's and has always been well maintainded and has had a recent full service and tune up. But when I start it up when it cold it revs real low/ kinda rough. And when I take off it goes slow almost wants to cut out i think some times. Once I started it and put my foot down and it cut out . It also backfires or something sounds like it in the inlet manifold occasionally. Any ideas would help.
    May 2009
    Wellington
    Not to confuss. The tune up and service was about 6 months ago now. Also the fuel pump is kinda noisy is this normal. And could the AFM be the problem. Cheers Jake
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    sounds like your Air Flow Meter(AFM) is on its way out.. its a very common thing with the Vl commos.
    Fuel pump sounds like its whiring irs also a common thing but not of concern. my last Vl had the same thing it was a noisy fuel pump but no dramas.
    With your AFM try another off a working vl if possible or test one from wreckers b4 u buy..
    backfires can cause the hot wire in the afm to snap as it is very small in gauge..
    if u unplug your afm and start your car does the idle smooth out and then as soon as you touch the throttle it will stall.(give that a go)
    and when u plug it in while its idleing does it get rough again.?
    May 2009
    Wellington
    May 2009
    Wellington
    Yep prety sure it the AFM. cheers 4 d help
