Results 1 to 9 of 9
Thread: Tutorial.
    Berlina VL
    Nov 2009
    Default Tutorial.
    Would anyone have a guide video/pictures of how I would change my RHS headlights of my Holden Berlina VL. Had another car reverse into it. Where would I start ? Thanks.
    Skidney's Avatar
    Skidney is offline Utes do it better.
    VP UTE
    Sep 2009
    Adelaide CBD
    Just open your boot mate and there should be some pretty obvious screws to remove, then it should just pop out.
    cheers
    93 VP Ute, V6 5 Speed
    Berlina VL
    Nov 2009
    I was referring to the front (bonet), wasn't sure which screws I'm meant to remove. Didn't want to take out the wrong screws and not be able to put it back, lols.
    Sabbath''s Avatar
    Sabbath' is offline Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    Pretty sure you have to take the trim strip off to get the two lower scres, then there are two screws on the top.
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    not that hard, just look whats holding them in..should just be 2 screws on top.. i doubt theres any under the bumber holding them.
    Nackerz's Avatar
    Nackerz is offline Rollin
    2 n/a vl's 1 twin turbo vl vn ss vy sv8
    Jul 2009
    Berlina VL
    Nov 2009
    Hrms, since only my lense, well outside glass (clear) part got smashed, would I have to replace the entire head light, or could I just change the lense ? It seems to be clipped on, am I right ?
    Nackerz's Avatar
    Jul 2009
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    remove bar first - 4 bolts on side of rail under the car - 2 bolts from under inside under the guard to the bar ends,
    remove grill - 2 screws from the front in then bottom grill slot
    remove side upper bar moulds - screw in end of mounld to guard - bolt from under headlight panel too mould - then squeeze some clips and will remove side ways of car
    center mould - using flat head screw driver pop off clips near middle and remove mould
    to bolts for head light are accesed from openings on top with the bonnet open
    and two are located under the head light
    un plug loom and your done
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
  1. Tutorial.
    By vlteclol in forum VL Holden Commodore (1986 - 1988)
    Last Post: 27-11-2009, 05:20 PM
  2. Tutorial: VH front end onto a VB/VC
    By VS Omega in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 25-04-2006, 01:41 AM
