Results 1 to 9 of 9
Thread: flutter
    VL Berlina
    Oct 2006
    Peterborough, SA
    Question flutter
    hey. when i start the vl up, put my foot down and theres a slight flutter but once it gets over the flutter it sounds fine. wat could this noise be
    whitey152's Avatar
    whitey152 is offline cruzen
    1996 vs berlina
    Jul 2008
    port macquarie
    Nackerz's Avatar
    Nackerz is offline Rollin
    2 n/a vl's 1 twin turbo vl vn ss vy sv8
    Jul 2009
    VL Berlina
    Oct 2006
    Peterborough, SA
    yer nah no turbo...yet. but yer just wen ya stand on it it makes a fluttery noise for about one second then its ok.
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    could be a few things and vl are known to have that stutter/slight flat spot on acceleration.
    i would suggest clean out dizzy and inspect rotor arm and contacts inside cup.
    clean or replace plugs
    inspect leads as well (replace if necessary)
    fuel filter change
    clean out throttlebody(take off car and completely clean it get it shiny)
    or further clean intake runners and plenum as well
    also check air filter (replace if necessary)
    afm setting not too rich
    electrical plugs/contacts clean and not corroding.
    run some injector cleaner through it
    AAC valve functioning correctly as in inner pin not sticky
    fuel reg working correctly
    i would think once gone through this list you should get on top of that stutter/flutter
    this is what i do when it gets a bit funny
    let us know bud
    goodluck
    Nackerz's Avatar
    Jul 2009
    premium's Avatar
    premium is offline P-Plater
    1988 VL Berlina, 1985 VK SL
    Sep 2009
    Williamstown, VIC
    mine makes a odd noise when it starts cold, but it's just because the oil hasn't properly circulated yet. I wouldn't worry about it.
    Quote Originally Posted by premium View Post
    high-performance sunroof?
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    r u talking about a tapping noise when cold???
    thats lifters till oil gets up to top of engine..
    need a clean and fresh oil :P
    VL Berlina
    Oct 2006
    Peterborough, SA
    hey cheers for that. ill try the list asap and get bak to u
  1. Engine Flutter
    By rlb in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-12-2005, 04:58 PM
  2. Flutter
    By Dead Head in forum VL Holden Commodore (1986 - 1988)
    Last Post: 23-11-2005, 12:06 PM
