i own a series II vl berlina just swaped the engine hooked everthing up as it should be it has spark and it starts when i spray airostart down the air intake so it makes me think that it must be fuel i have checked the fuel pump for pressure and change fuel pressure regulators and computers now its just doing my head in. could a sensor be the problem?
hows about the injectors??
r they getting power to work correctly?
check fuses relays etc.
echaust leak wont stop it from starting
try the battery trick
Love the Sig VK.jonno Bahahaha he thinks its a turbo not a diff
50Psi would be enough to get fuel to your cylinders regardless
what about your fuel reg??
what year engine did u put in i ? had the same problem when i did it but i just had to splice a wire in the ecu loom for the petrol pump and it started strait away
bit of a dig there bud last post was 2/12/09
