Just finished installing extractors and a resprayed rocker cover, jumped in turned the key, wouldnt start. then remembered i didnt plug in the oxygen sensor. So did that got back in turned the key, and did the same thing. Tried disconnecting and reconnecting battery, made sure afm and everything was plugged in properly and still wont start. Anyone know what i should try?
as in not cranking or not firing..???
hows the battery got charge??
problem is solved.. all running again and extractors make it sound fair good
the bit that plugs into the top of the distributor had alot of white/green powdery stuff built up, so got the wire brush and got rid of all that, sprayed a tad of wd40 on it, plugged it back in and started first go![]()
yeah thats the plug for the CAS mate they have a habbit of that!
