hey guys i was just wondering if anyone new roughly how much boost u can run pump into a standard vl turbo and keep it safe. itercooled or not intercooled
ive always been told 10psi nonintercooled and 12 psi intercooled but thats only what ive been told so good luck trying it
Its all in the tune. But apparently after 14psi is maxing the stock vlt injectors out. Thats intercooled.
1988 VL Berlina turbo 5 speed
http://forums.justcommodores.com.au/...ml#post1446411
1987 VL SL turbo 5 speed ~STOLEN~
http://forums.justcommodores.com.au/...ed-manual.html
noob question: can you run a turbo with stock injectors, computer, etc?
yes, my wagon is running a highflowed t3, running 7psi with N/A injectors and N/A ecu. Tho i do have vlt injectors and ecu sitting in the shed.
i'd only run standard boost which is 6 or 7psi on a non-intercooled one, and if its a hi comp model max about 10psi unless its tuned for more, but if its a turbo block should be able to handle 14psi if its tuned, keep it safe on 10psi with a front mount.
Sleeper Wagon - In the Build
VP Executive series 2
Check out My Ride
Current ModsWidened S/C CAI, 2.5" exhaust, Advance headers, no bellmouth, 17" VY SS, Foamy TuneFuture ModsNew CarWantedMONEY!!!
