Results 1 to 24 of 24
Thread: Few Conversion Questions Fellas N/A - Highcomp Turbo
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    Default Few Conversion Questions Fellas N/A - Highcomp Turbo
    Firstly guys is mainly with the position of the AFM i have seen some in the original place B4 turbo and i have seen some mounted in cooler piping near dizzy/rocker cover.
    I have read some experience problems in cooler piping as when letting off under boost sudden drop of intake pressure the Ecu does not adjust quick enough causing rough idle and low revs is this true???
    Second is correct plumbing with Vac lines.. do i go say from turbo housing to a "T" piece then to bottom port of the External Wastegate and the other line from T piece goes to the Manual boost controller(MBC) then on to top port of wastegate?
    As for blow Off do i plumb a line from intake piping/intake plenum to top nipple of blow off valve?
    thirdly what oil is recommended for a turbo engine what viscosity should i use??
    is 20W-50 ok what i use already?
    and lastly what is a good timing degree for a high compression convert do i basically adjust/fine tune to avoid pinging/detonation. Yes im running a Cooler
    Thanks heaps for your help in advance and feedback. hopefully some turbo experienced blokes can give us a hand?
    Out...........
    VL Berlina turbo, VL SL turbo ~STOLEN~
    Aug 2007
    Newcasstle
    [QUOTE=detox_nath83;1389264]Firstly guys is mainly with the position of the AFM i have seen some in the original place B4 turbo and i have seen some mounted in cooler piping near dizzy/rocker cover.
    QUOTE]
    Pretty sure the first problem u mentioned with rough idle and low revvs is when the afm is located infront of the turbo. Apparently less problems with afm in piping... and it sounds cool, flutter/dose ftw.
    U dont need a t piece for boost controller. Just cut the vac line in half insert mbc. The top port on my external gate isnt used for anything?
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    VL Wagon 5 Speed
    Sep 2009
    ... and my mate has the coolant lines cut to the plenum chamber, because apparently it's unnecessary in oz because the line's only there for freezing weather, this true? so to keep your cool intake do this.
    Nackerz's Avatar
    Nackerz is offline Rollin
    2 n/a vl's 1 twin turbo vl vn ss vy sv8
    Jul 2009
    Hey mate, i just put the turbo setup on the vl, i had the afm in front of the turbo it ran like SHIT so i put it in the coller piping HEAPS better now...
    I haven't recieved my boost controller as yet, but with out it i hit 20psi boost yesterday without pinging no tune, stock N/A injectors (got turbo ones to go in), stock ecu, and stock A6 with intercooler
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    Quote Originally Posted by detox_nath83 View Post
    Out...........
    as said before ive heard also that its inftont of the turbo that has probs
    ive got mine in the cooler piping under the rh rail and its fine
    external waste gate im not sure
    same with bov
    oil depends ont he engines condition, im using 20w 50,
    timing wise, started at factory then advanced it slightly till it was good,
    alos i only run premium
    Quote Originally Posted by Nackerz View Post
    sounds like a nasty boost spike there
    i would be getting your waste gate spring looked at as its spiking/creeping
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
    Nackerz's Avatar
    Jul 2009
    i have an external gate as you have figured out lol, well when i put it on i was not getting boost at all, i had the bottom port of wastegate to front turbo housing and the top too atmosphere, no boost...
    changed it around so the top port went to front of turbo housing and bottom to atmosphere, my mate was helping me (he has a bt1 and a turbo wagon) and it boosted fine and normal he said..
    i have no boost controller im still waiting on it
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Quote Originally Posted by tombomb View Post
    yeah i have heard about this also cheers man,,
    its explained when putting an XF throttlebody on the RB30 to bypass the coolant lines from T/B
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    doesnt the N/A injectors max out at 7psi??
    thats what i have heard anyways ?:P
    cheers for input Guys....
    Hey 5Speed have you got a pic where u have located your AFM can it be affected by water??
    Nackerz's Avatar
    Jul 2009
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Nackerz's Avatar
    Jul 2009
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    the bottom hose is where you feed boost in so it pushes open at the moment it will full boost you have 0 control of boost its trying to hold the gate shut on boost very bad idea
    Nackerz's Avatar
    Jul 2009
  15. #15
    в∞ѕтεכ √&
    Jul 2008
    NZ
    does the wastgeate even have a spring in it should be making at least 7psi if it has a spring in it .if you are taking the wastegate feed off the compressor housing there may be a major restriction on the way to the manifold and its opening the wastegate before the plenum sees boost but it would have to be a big restriction LOL
  16. #16
    Nackerz's Avatar
    Jul 2009
  17. #17
    в∞ѕтεכ √&
    Jul 2008
    NZ
    the pressure feed to the wastegate is it from the turbo compressor housing on a brass nipple of from the plenum
  18. #18
    Nackerz's Avatar
    Jul 2009
    its from the brass nipple on the front of the turbo housing. heres a pic
    its just under the blu silicone joiner there in the middle and goes to the wastegate
    add me to msn if you want too help me out instead of waiting for me to reply as i would love to get this fixed asap
    djsexy-boi@live.com.au
    NOTE: im always signed in but appear offline so just send me a message and i will reply
  19. #19
    Nackerz's Avatar
    Jul 2009
  20. #20
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    can the AFM go after turbo but b4 intercooler without any probs (In the red piping on Nackerz Setup)as i have recieved a cooler kit today.. i can cut the afm into it as Nackerz has done on the walky if not but would be easier if it can go b4 cooler.
  21. #21
    Nackerz's Avatar
    Jul 2009
    pretty sure it can mate ... my mate has his after the cooler but at the bottom near the fan and that is just to hide it but still works....
    as long as its after the turbo and before the throttle body your right i think? im not 100% sure so maybe someone else can help on that one
  22. #22
    в∞ѕтεכ √&
    Jul 2008
    NZ
    after the cooler makes more fueling changes for air temp its a lot colder after the cooler
  23. #23
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    i would be worried about water that low down. i may put it where u have Nackerz quite easy really then it is up high and after the I/C
    Thanks fo your help guys appreciate it
  24. #24
    Nackerz's Avatar
    Jul 2009
    yeah nah probs
  1. [Ecotec] Turbo Questions
    By sweefu in forum V6 Development And Modification
    Last Post: 16-11-2009, 08:50 AM
  2. a few V8 conversion questions
    By Fun_Bucket in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-11-2009, 02:39 PM
  3. Rb30 N/A Conversion to ET Questions Thanks fellas
    By detox_nath83 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 13-05-2009, 07:54 PM
  4. Lexcen Turbo Questions
    By randomhero11 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-11-2008, 03:30 PM
  5. na vl turbo questions....
    By Youngblood in forum VL Holden Commodore (1986 - 1988)
    Last Post: 15-09-2007, 04:41 AM
