hey guys. ive bought a new genuine master cylinder from holden and i need to put it on my VL. i need to get a blue slip for my car and a few other things by my mechanic so im just wondering how much it would cost to change ? hours it will take etc...
thanks
its quite easy but messy
you need to drain the brake fluid first,
then simple as unplug brake switch, unbolt the brake lines, front mount braket and the two bolts too the brake booster
replace with new one and bleed the brakes,
hour or 2 it should take
My Rides
Project VEE EL
Yamaha YZ250F
My 'other ride'
The Aussie PackMule
SA JustCommodore Section
i know that but i really cant be bothered and with heaps of work now i dont have that time so ill just drop it off at a mechanic. so im probably looking at $150 labor am i correct ?
i rang the our mechanic and it is $85 to change.
hi im getting it done on the 11th. i range the mechanic is a mate of ours. its $85 for labour. i already bought the ms brand new genuine for $180. so pretty much $85 and the brakes will work lol
