I heard that VL turbo injectors are hose tail, is that right?
What do they flow cc/min?
Where can I get second hand or new injectors for VL turbo?
K12
New injectors are availiable from most speed shops.Be warned,they're $180 each.I,ve replaced 3 so far,now another one is leaking.I think i will just let it burn.
If you take out the fuel rail to change them,just drop the fluid,then split the intake manifold in half [remember there are 3 bolts underneath] and replace the gasket.Takes about 25 mins.If you go by the workshop manual, takes hours.Hope that helps.
ANYONE WANT A CALAIS TURBO BEFORE IT TURNS INTO A FIERY MESS?
