Results 1 to 10 of 10
Thread: vdo temp sensor to suit 6cyl vl
    vl
    Apr 2008
    Default vdo temp sensor to suit 6cyl vl
    hi all,
    im installing a vdo eletric temp gauge in my vl and im not having any luck with a sender unit to suit.
    ive got a sender here but its to long but looks to be the right thread, part no VDO 320.002
    repco have sold me 3 different sensors now and none fit and i realy need this gauge working.
    does anyone know what sender will suit a VL?
    thanks guys.
    Nackerz's Avatar
    Nackerz is offline Rollin
    2 n/a vl's 1 twin turbo vl vn ss vy sv8
    Jul 2009
    vl
    Apr 2008
    Quote Originally Posted by Nackerz View Post
    cant u use the stock electric sender in it???
    i was thinking that but it would be better to have a sender unit that matches the gauge i would think.
    anyone know the temp range of the standard 6 cyl temp sender?
    thanks.
    Nackerz's Avatar
    Jul 2009
    wat u mean by the range?
    my mates has a gauge for his temp and wired too the original sendor his sits on like 70degrees and he thought that was high so he took too the mechanics and they said it was all good
    vl
    Apr 2008
    all temp sensors have a working range that matches to the gauge, IE my VDO gauge has a range of 40c- 120c so i need a sensor with the same working range.
    if you use a gauge with a range of 40c-120c and a sensor with a range of 60c-150c you will be getting an incorrect reading.
    i might wire it up to the original sensor and see how it goes but id really like to know how accurate it is.
    any idea how accurate your mates is?
    would have thaught 70c normal operating temp would be slightly on the cold side especially for this time of year?
    thanks.
    Nackerz's Avatar
    Jul 2009
    vl
    Apr 2008
    it goes to about 80 on a hot day!
    not sure how accurate it is but works all good lol
    i get ya now just didnt know what ya meant dir me hahaha
    nah thats cool mate, lol.
    any help is much apreciated.
    well i did a test with some hot water in a jug with a VDO sensor with a range of 40c-120c hooked up to a VDO gauge with a range of 40c-120c and my mates very expensive thermometer and found the VDO sensor to be spot on as you would imagine BUT when i did the same with the original VL sensor i found its out by about 10deg celcius (reads cooler than the water realy is) but that gets worse the higher the water temp gets. at a water temp of 80deg the VL sensor only reads 60deg.
    Nackerz's Avatar
    Jul 2009
    well you can just hook it up and go by a rule of thumb
    what temp was the water at when it was 10deg out
    i geuss its... 40deg on gauge equals 50 deg water
    60deg on gauge equals 80deg water temp
    80deg on gauge equals 110deg water temp
    just go by that mate
    or if ya just put it in with the vl sensor and gauge hooked up to it see what it reads at normal running temp and note in your head what it is and if it goes up higher then that your in trouble
    vl
    Apr 2008
    yeah i was thinking that, just use it as a rule of thumb but i would realy like it to be accurate.
    my findings with the VL sensor were
    real water temp what the gauge said
    50deg - 40deg
    80deg - 60deg
    so my next idea is to drill the sensor hole in the thermostat housing out bigger, tap a new thread that will suit a VDO sensor, bung a new VDO sensor in and all should be good, hopefully.
    Nackerz's Avatar
    Jul 2009
    yeah that would work mate just be very carefull when you drill the bugger
  1. [NSW] FS: 5spd to suit VB-VK 6cyl(whole conversion)
    By RACE5L in forum Swap / Wanted to Buy / Trade
    Last Post: 03-12-2009, 04:34 PM
  2. Q's regarding Coolant Temp & Intake air temp sensor
    By Steven M in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-02-2009, 05:08 PM
  3. Converting VR Tacho to suit 8cyl from 6cyl
    By Fuzzypumper in forum Electrical Wiring / Questions
    Last Post: 14-07-2008, 03:05 PM
  4. A4 Oil Temp Sensor
    By Leno in forum VY Holden Commodore (2002 - 2004)
    Last Post: 30-08-2007, 08:19 PM
  5. WTB: Airflow meter - suit vk 6cyl efi
    By Shifty1 in forum Swap / Wanted to Buy / Trade
    Last Post: 25-03-2006, 04:46 PM
