Results 1 to 11 of 11
Thread: shutter on take off and had xlr8ing
    vr wagon, vx executive
    Jan 2005
    Default shutter on take off and had xlr8ing
    go our vl executive rego yesturday. wooohooo. but when we take off from a standing start on xlr8 hard there is a shutter in the car.(gearbox, tailshaft, diff? )engine does have a slight miss fire, will service next week. i have had the 18" wheels balanced, fitted new slotted disc rotors and pads so i know they are all good. What is your ideas on the shutter? is it talky, gearbox (changes gears fine), tail shaft or diff?.
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    Shudder is usually caused by trans slipping, engine/ trans rubber mounts, tailshaft bearing or diff.
    Nobody wants to play with me
    Jan 2005
    it passed rwc last week. i will get under it tommorrow and check the mounts for movement and check oils in trany and diff, thanks jatsvl your are very helpful
    Nackerz's Avatar
    Nackerz is offline Rollin
    2 n/a vl's 1 twin turbo vl vn ss vy sv8
    Jul 2009
    with your tailshaft if you drop it out of the diff does it drop down heaps?
    this should be so
    if not the bearing has been replaced and tailshaft not joined back together correctly
    or if it hasn't been changed that you know of...where the centre bearing for the tailshaft is in the middle of the tailshaft if you can push it towards the bottom of the car (so up when underneath the car)
    and it has alot of play it will need replacing if you get stuck yell out and i or jatsvl or anybody else will be glad to help you out mate
    86 VLCT/ 03 II VY SS Ute
    Aug 2007
    Jan 2005
    changed tailshaft with a spare (no different) but notice gear box mounts broken. i have replaced the mounts tonight so i will try it again in the morning. also felt the gears going up and down cruising between 80-100 but when i put the power button on its fine. is my gearbox in need of replacing?
    jatsvl's Avatar
    vl exec wagon
    Nov 2006
    that is the torque converter clutch (overdrive) engaging and disengaging, and it is normal putting pwr button cancels fourth/overdrive.
    nathanVY's Avatar
    nathanVY is online now need boost...
    03 VY Calais, 99 VT Equipe
    Dec 2009
    Geelong, VIC
    Quote Originally Posted by minimefx View Post
    I have the same problem in my VR, shudders when you accel hard. It passed a RWC last week too, turns out the left hand engine mount is broken.
    Jan 2005
    jatsvl's Avatar
    vl exec wagon
    Nov 2006
    no more shudder now i changed the gearbox mounts
    good to hear! did you buy new or second hand because new is worth shopping around for there is a huge price difference on MACKAY mounts depending on where you buy them. I found RAPCO very expensive and a different price for left and right.
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    Quote Originally Posted by jatsvl View Post
    REPCO.....
    Rip Every Poor C*n# Off
    Just my 2 cents :P
    Nice to c its all fixed up :P
  1. Anyone seen the movie "shutter"
    By cruzncommo in forum The Pub
    Last Post: 03-01-2008, 12:19 PM
  2. shutter/vibration on highway??
    By gupatrol in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-12-2007, 11:04 PM
  3. Vibration or shutter at take off
    By nevj in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-12-2006, 10:06 AM
  4. Shutter in the rain random
    By seveprim in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-09-2006, 09:57 PM
  5. power steering shutter
    By btsmash in forum VY Holden Commodore (2002 - 2004)
    Last Post: 28-05-2005, 01:02 PM
