Results 1 to 14 of 14
Thread: running on 5cyl
    vy2 clubsport
    Feb 2008
    adelaide
    Default running on 5cyl
    running on 5cyl
    hey all i got a bit of a problem my vl is running on 5.ill let you know what ive checked and replaced and if any one can throw up some answers or tell me what to check that would be much apreciated.
    new head gasket.
    6 new plugs.
    new rotor button.
    ive checked the ohm's of the leads they are fine.
    ive ran a compresion test and its all good 130-135 acros all 6
    should i be checking the coil maybe the spark isnt strong enough?
    any other ideas?
    thanks in advance
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    not really coil as its fine with other cylinders
    could be a lead man regardless of a test. how about the dizzy cup as in the contacts inside it could possibly have a crack causing it to earth out through it and not travel along the lead
    Possibly be an injector problem as well,
    test injector for the specific cylinder.
    Could also be a plug problem. my step dad changed over plugs for his vnv8 commo and it ran on 7 cylinders. turn out it was a faulty plug from manufacture.
    i doubt it........... but could be CAS starting to fail...
    goodluck bruz let us know
    GetToDaChopa is offline Blues Brother # 2
    The Blues Mobile
    Dec 2008
    Western Sydney
    vy2 clubsport
    Feb 2008
    adelaide
    ok the leads all tested 12 ohm's
    i tryd old plugs plus new plugs but im going to gap plugs to .8 and see what happens maybe the spark is blowing out
    Nackerz's Avatar
    Nackerz is offline Rollin
    2 n/a vl's 1 twin turbo vl vn ss vy sv8
    Jul 2009
    possible it is blowing out, have the car running and pull each lead off one at a time to see which one it is, then run a series of test on the cylinder.
    you could just swap a lead around and see if it is the lead, swap the spark plug over see if it is blowing out, when you have the plug out put it in the lead start the car and see if it is sparking, also check if that cylinder is getting fuel
    vy2 clubsport
    Feb 2008
    adelaide
    plugs are new leads are fine did it with old plugs.doubt the spark would blow out now that i think of it only on hard throttle it would.
    trying .8 in the gaps
    vy2 clubsport
    Feb 2008
    adelaide
    all getting spark,all getting fuel.
    gaped the plugs still running a bit rough.
    distributor cap is my next step mite aswell get a new one
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    even when testing a lead, still may be a fkd lead.... or dicky plug on end of lead where it is crimped to the core could be contacting most of the time then not contacting
    Nackerz's Avatar
    Jul 2009
    vy2 clubsport
    Feb 2008
    adelaide
    getting whole new dizzy most prob the cas i here cause when it gets to operating temp it dies.
    yeah what are the chances that i have 2 sets of plugs and in each set one is nackerd but will try lol
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Nice man c how u go. let us know.
    It may be something dumb like the slit in the CAS disk for the cylinder may have debris causing it not to read when it moves through the sensor
    Even pull dizzy apart and inspect for orange powder from a bearing dust seal under CAS this causes debris to block the slits on the ally disk. If u dont know what im talking about search my thread Step By Step Guide for Replacing the Crank Angle Sensor (CAS) on an RB30
    vy2 clubsport
    Feb 2008
    adelaide
    cheers mate
    well found the problem number one injector lead [ plug on injector wire ].it would run shit but if i put a bit of pressure on the plug that connects to injector it ran sweet and on all 6.very happy now
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    vy2 clubsport
    Feb 2008
    adelaide
    fkn vl's lol gota love them thoe now i can re rego it
  1. VS V6 running hot
    By jakewaze in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-12-2008, 11:17 PM
  2. what cam is everyone running in their vn vp v6 or v8
    By Zuicider in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-11-2008, 11:12 AM
  3. Vr running like cr@p,CAS?
    By Muik in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-10-2008, 05:25 PM
  4. VR Engine light stays on running running alittle rough
    By AJKoo1 in forum General Discussion
    Last Post: 07-09-2006, 01:08 AM
  5. running on 5cyl
    By minimefx in forum VL Holden Commodore (1986 - 1988)
    Last Post: 23-04-2005, 01:56 AM
