Results 1 to 6 of 6
Thread: Fault Codes 4 ECU Question
    VL 86 RB30 Executive Auto
    Jun 2005
    South OZ Adelaide
    Default Fault Codes 4 ECU Question
    Hi guys I came across these fault codes on the 17/06/05 which said turn the screw on the side to put ECU in self diagnostic mode and see which codes come up, well say 12 (AMF CODE) 12 WHAT? blinks of the red LED or Green LED or is it 1 RED and 2 GREEN blinks not the number 12.. HELP!!! :b:
    VL SL 86
    Jun 2005
    Exclamation LED Codes
    Hey MAG,
    Red for tens, Green for units.
    ie 12 is 1 Red the 2 Greens.
    12 means that the ECU has determined that the signal from the Air Flow Meter, the bit between the air filter and the manifold that has a data cable connected to it, has gone outside an acceptable range of values.
    The LEDs flash in sequence that is repeated until the thing that you turn with a screwdriver is put back in the anticlockwise position.
    the sequence is for example for codes 12, 14, 31:
    Long pause,
    1 red 2 green, short pause,
    1 red 4 green, short pause,
    3 red 1 green
    repeat
    hope this helps
    Jun 2005
    South OZ Adelaide
    Quote Originally Posted by hz2vl
    Hey MAG,
    Long pause,
    3 red 1 green
    repeat
    hope this helps
    bloody good stuff hz2vl and bloody quick too !! thanks
    Jun 2005
    South OZ Adelaide
    Lightbulb how many codes
    guys how many fault codes should there be?? I have 11 codes!
    mohican Guest
    hey how you doing i was wondering if any one would know why my vl is only sitting 2000 and wont go over and what would be the code to find it out
    Jun 2005
    South OZ Adelaide
    Default codes
    maybe code 23, 4 the throttle circuit.
  1. fault codes
    By kasey375 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-07-2006, 06:31 PM
  2. fault codes!
    By Torquen in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-05-2006, 06:23 PM
  3. Fault Codes....
    By Hairy Eater in forum General
    Last Post: 15-01-2006, 07:21 PM
  4. question on fault codes
    By Philth in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-09-2005, 01:03 PM
  5. vr fault codes
    By vlcalaisturbo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-06-2005, 01:17 AM
