Page 1 of 2 12 LastLast
Results 1 to 25 of 41
Thread: push brakes n no lights!
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    Default push brakes n no lights!
    title says it all, any idea's?
    the lights work with the headlights on, though pushing the brake doesnt make them brighter.
    Quote Originally Posted by Jamie-b View Post
    well i think a "headjob" would be better than stroking it?
    Road trawling paddock bomb = moody VL
    Jul 2009
    goldfields VIC
    sounds a tad silly but have your checked they arent blown?? i know its odd but at an auto elec shop i use to work at we had an el fairmont come in with that problem.....we replaced the spring switch above the brake pedal and it still didnt work so we checked the globes only to find we had been a bunch of twits....may be the globes, may be the switch, could be neither but its just a couple of ideas
    Jul 2009
    goldfields VIC
    oh and when i said check the globes i know your tail lights are working but theres that one in a million chance that just the brake light element could have blown
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    Thats a Bad earth problem if globes are good.
    check for corrosion in the plug terminal as well as the spade connecters crimped on to the wire in back of plug.
    i had this for one side of my lights and it was the earth
    Goon's Avatar
    Feb 2006
    GC. QLD
    cheers guys, ill inspect it after and let ya's know!!
    thanks again!
    vy2 clubsport
    Feb 2008
    adelaide
    Quote Originally Posted by detox_nath83 View Post
    yep as what he said they are prob rusted if the are just get new tail light loom
    STEALTHY™'s Avatar
    STEALTHY™ is offline So Wet For You!
    VP Calais International, VP Berlina LX Wagon
    Jan 2005
    SA - The Roadworks State
    All wrong. It'll be the switch on the brake pedal (chance of ALLLLLLL 4 blowing just one filament, not likely)
    If you do a search for brake pedal switch, i'm sure the thread with pics of how to fix it will show up (might not be from a VL tho, but this is a common commodore problem)
    Quote Originally Posted by davway
    Improved Suspension Reduces Handling!
    Quote Originally Posted by JONNNNOOOOO!!
    cheers sexy
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    stealthy he said it was not all filaments at all man just not lighting up.
    i have had this prob and it was a bad earth and a common prob with the vk as well.
    but like u said could be the switch.
    all is possible
    Goon are the secondary filaments blown in the rear bolbs..
    STEALTHY™'s Avatar
    Jan 2005
    all is possible
    He said none get brighter. Meaning if it was the 'globes' it would be just one filament per bulb blown. Not likely
    I had the same problem with my VL, no brakes lights, only 'driving/parkers' and it was the switch on the brake pedal
    cheers sexy
    Jul 2009
    goldfields VIC
    STEALTHY™'s Avatar
    Jan 2005
    Quote Originally Posted by aussie_macca View Post
    isnt that one of the two options i listed in the first response? lol
    Indeed it is, i stopped reading after blown globes (which is the trend of the other responses too) my bad.
    cheers sexy
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    fuse, globes, corrosion, then brake light switch mate,
    Nobody wants to play with me
    Goon's Avatar
    Feb 2006
    GC. QLD
    it was the SWITCH guys, thanks.. i did a bypass and it works, so im going to adjust it and try and fix it.. if not buy a new or 2ndhand one!!
    Goon's Avatar
    Feb 2006
    GC. QLD
    all good now, got another switch from the wreckers, cheap as chips first go it worked so yeah im happy!! going for a drive now! thanks gang!!
  15. #15
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
  16. #16
    vy2 clubsport
    Feb 2008
    adelaide
  17. #17
    jatsvl's Avatar
    vl exec wagon
    Nov 2006
    Quote Originally Posted by bow down View Post
    true but you just dont jump to the switch you start at the obvious
    seconded!
  18. #18
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
  19. #19
    STEALTHY™'s Avatar
    Jan 2005
    The switch IS the obvious problem. Have a think about it, the chances of ALL 4 shorting out on the same day, highly unlikely. 99 times out of 100 it will be the switch if that is the problem your having. If you still have one or more brake light working, then its not the switch, simple really
    Aussie Macca mentioned it first btw, i just didn't see it in his post lol
    cheers sexy
  20. #20
    vy2 clubsport
    Feb 2008
    adelaide
    and like said before he never stated first that all the tail lights were not working.so with the info we had we said check the tail light loom.
    cheers
  21. #21
    STEALTHY™'s Avatar
    Jan 2005
    Quote Originally Posted by Goon View Post
    Read his post again
    Headlights on (driving lights) but no brakes = brake pedal switch.
    Double cheers
    cheers
    cheers sexy
  22. #22
    jatsvl's Avatar
    vl exec wagon
    Nov 2006
    Quote Originally Posted by STEALTHY™ View Post
    Read his post again
    Headlights on (driving lights) but no brakes = FUSE
    Double cheers
    last time my brake lights were out it was the fuse!
    blow any harder you'll pop a vain.
  23. #23
    calais24/7's Avatar
    calais24/7 is offline Mucca Mad Boys
    VS Calais II 5L, 98 rodeo v6
    Jul 2009
    Mine has just started to do this Is it a piece of piss to remove and install that switch? Rofl it's not the globes but i'll have a look tommorow in regards to the switch.
  24. #24
    STEALTHY™'s Avatar
    Jan 2005
    Quote Originally Posted by jatsvl View Post
    You know what a fuse is for right? it means theres a problem somewhere else. Simple replacing the fuse wont fix your problem. The most common reason for ALL the brake lights to stop working at once, is the brake pedal switch, as proven by the OP in this thread.
    cheers sexy
  25. #25
    jatsvl's Avatar
    vl exec wagon
    Nov 2006
    water in the tail lights caused a short and blew the fuse only noticed a few days later when I was told I had no brake lights funnily enough the tail lights worked just fine because they weren't on when the water was in the lights, when I checked for corrosion I noticed water marks so I sealed the lenses and changed the fuse. this I'm sure you would know is a common VL problem.
  1. push rods for a 5.7
    By loveless in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-05-2009, 08:42 AM
  2. what amp will push these subs better?
    By nips69 in forum Car Audio
    Last Post: 05-12-2008, 05:28 PM
  3. need a push
    By kowan in forum Jokes/Humour
    Last Post: 27-06-2006, 11:52 PM
  4. Brakes/lights/cold starting
    By groucho in forum VL Holden Commodore (1986 - 1988)
    Last Post: 18-05-2006, 06:42 AM
  5. park lights come on when brakes applied help
    By 94 VR BT-1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-03-2005, 04:46 PM
