Results 1 to 6 of 6
Thread: VL calais eyelids
    VLC86's Avatar
    VLC86 is offline ..stay N/A..
    VL Calais
    Dec 2009
    Default VL calais eyelids
    anyone know a possible cause for my calais's pop up lights not to work? the lights will be
    on but the eyelids wont be up. i know the motor works perfectly because i can manually
    wind them up, and when the battery is connected up again they close themselves.. but the
    lights work just fine so somehow the power isnt getting to the motor. is it possibly the
    relay? how could i check whats going wrong? anyone been able to fix the same problem?
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    i would think its not a fuse problem as they close when powered, thus being connected, maybe a sticky relay yes or a bad connection to the motor from relay, use a multimeter to isolate the problem
    VT HBD LS1, VL calais project
    Nov 2009
    SE bris
    the relay is a common prob with the eyelids... relay is behind the drivers side headlight, there is 2 or 3 relays there.. try one of the other relays in the eyelid one and see how ya go..
    Larry
    vn_v6's Avatar
    vn_v6 is offline Blumpkin
    87 vl limited edition
    Aug 2009
    victoria
    neighbor had the exact same problem, its the relay, went wreckes, got handufl of same coded ones and fixed the problem
    VLC86's Avatar
    VL Calais
    Dec 2009
    hey guys. i got it working, i tried the few relays near the battery and found the right one.
    thanks for the help
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    nice man..
    well done.
  1. [NSW] VK Door trims Berlina & Calais + VL Calais
    By vkberlina in forum Parts And Other Items For Sale
    Last Post: 03-10-2009, 07:41 PM
  2. [SA] vx calais altezza monaro lights and vt/vx calais doors
    By callum_88 in forum Parts And Other Items For Sale
    Last Post: 24-04-2009, 01:33 PM
  3. Replies: 0
    Last Post: 26-12-2007, 11:34 AM
  4. Replies: 7
    Last Post: 27-02-2007, 03:55 PM
  5. VL Calais eyelids help
    By derelict_unit in forum VL Holden Commodore (1986 - 1988)
    Last Post: 04-07-2005, 01:29 PM
Tags for this Thread
