Results 1 to 5 of 5
Thread: should i disconnect the thermostat?
    crazy for vl Guest
    Default should i disconnect the thermostat?
    is that better for vl to drive it without thermostat because i already changed the head for once and i dont wanna over heat it again
    vlv8vic's Avatar
    vlv8vic is offline <---Brad Quaid = internet stalker
    M5
    Mar 2005
    Australia
    no dont take the thermostat out. the engine needs a little heat in it and you risk more damage to teh head through it running too cold. if anything a small (i mean like 2mm) hole can be drilled in the thermostat, or get one with a lower temp rating.
    it shouldnt do another head if you keep the coolant full and make sure you bleed the coolant when you fill it to stop air sitting in the top of the engines cooling system.
    VT
    Apr 2005
    QLD
    did you check all the water passages in the block? if they are restricted/blocked, that could be your problem right there...?
    VL Crapbox
    May 2005
    My thermostat was stuck open a month ago and it wouldnt heap up for 5 k's and also the heater didnt get real hot and she ran so rich. Al these things u must consider, if its running too cold it will be rich and you will burn juice.
    Just make sure you get the thing running hot and bleed both the nuts so there is no air bubbles in the system. The death of your head would have been because coolant got low, an air pocket was stuck in the top of the manifold and gas (air) gets hotter way faster so you would have super heated the air to about 150 deg, cracking the head.
    Use a thermostat, they are $30 smackers, small change for a smooth running car.
    If you want more inches, STROKE IT!
    vl berlina wagon 6cyl
    Jul 2005
    we all have to remember the 2 bleeder screws, or no water gets up there, causing a steam trap and a cracked head
    the highest water passage is higher thah the top of the radiator on the nissan VL 6
  1. how to disconnect high pressure fuel lines?
    By TheIceman in forum VY Holden Commodore (2002 - 2004)
    Last Post: 22-04-2007, 10:35 AM
  2. rust repair what do i disconnect
    By Matt_vp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-04-2006, 09:07 PM
  3. Disconnect my battery!?!
    By patullose in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-03-2006, 07:50 AM
  4. How to disconnect the heater control rod?
    By ProggerPete in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-02-2006, 01:11 PM
  5. Battery disconnect/reconnect while cranking.
    By VPCalais38 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-12-2005, 04:30 PM
