ok guys. recently i bought a new front kit for my vl as the other was broken. iim getting a blue slip on monday and theres a coupple little things i want to clear up before i go and fail.
1. the left indicator is loose. it wont fal out but moves around noticably if you touch it.
2. there is rust on the front screen. its not a hole or anything but its still there.
hopefully it will pass how it is but that would make my life a little easyer to know if n eed to fix anything up beforehand.
try to bog the indicator and how bad is the rust?
Is the indicator unattatched to the headlight? Just behind the lights there is a screw that holds the indicator to the main light. Its possible the indicator came loose and is just wobbling around. Dont lose it, they are hard enough to come across
ill have a look today. thanks for that.
the indicator itself works its just loose. the kit was smashed up aswell so i purchased another and put it on yesterday. now i need a bumper clip to put on to hold the bumper in place.
umm im not sure really about the rust its not big but its around 5cm long and you can see it through the rubber of w/screen aswell. on the left & right side of the car there about both equal.
you will have problem if you can see threw the metal
yeah im pretty sure that that area is a really common place for rust on VL's, i have rust in the exact same spot, mine isnt bad but defnately try to stop it from getting worse. Fish oil or some rust converter is good, itll protect the metal.![]()
yeh you cant see through metal. its getting very close. however if it passes (hopefully it does) around april ill be fixing all rust. re-painting. fitting rims lowering etc... all the works.for now i just want it on the road.
ok so i went to the mechanic today. had a quck look over the car. stopped at the rust. he said it had to be repaired. no way it would pass so i suppose that answered my question.
it is pretty bad and to do it properly we will need to take out the screen. for now were just going to bog it up and next few months were taking both screens out. repearing the car and paint it all.
hey yer were going to bog it up this weekend if we get the car back. the mechanic is just looking over the car... he is fixing the indicator so thats not a problem.
ok i got the car back on saturday. the mechanic done the light and the master cylinder.
however i need to change the rear muffler. (holes in it) the tyres are bald on the inside of them where on the outer and all through the middle there brand new. and also the rear suspension bushes. the cars all over the place.
then the rust and paint will go on it.
So you are in a panic to organise a safety inspection. How come your car was getting around with bald tyres, rust, brake issue (master cylinder), indicator light, suspension bushes etc. Didn't you realise that it was unroadworthy ? So much for annual vehicle inspections !!
id just bought the car and at the time all i knew that i needed to change was the master cylinder .... the rust is no problem we can fix it but when we changed the mc we told the mechanic to go over the car to see for any other problems before we went out to get a blue slip.
the tyres dont even seem bald in fact they have alot of tread however there is a wear issue. and i have to change all shocks/springs bushes because its just all over the place.
just keeping up to date on the site.
dont feel so bad my rwc cost 3 g's to get her back into roadworthy shape.. whole new exhaust, bushes tyers, control arms lol.. its what u get with an old car, cant expect to much, theres only a dozen out there in good nic.
best of luck bro, hit me up with any questions!
ps. if ur front tyers are warn in the inside eg. facing the engine, it probley needs a wheel alingment, 50 bucks there and worth it..
hey, yer the wheels do need an alignment ha my dad said it to me. i think one rear tyre is ok they said...
but umm my uncle has a HQ which hes fixed up so ill just use his stockys they should fit. otherwise tyres will need to go on my new 18" rims a little earlier than expected.
