ok i know this is abit like many other threads but i still thought i should do it as none had exactly what i wanted!!
im curious to know what the prices are for the following
k&n air filter? everybody speaks of them
or
pod filter? im not 100% sure if there the right names!
also types of chips?
can chips be added to just stock vl's?
and what are they worth like an average?
ummm... also other performance like add on's that are reasonably cheap..
say $200?
ooh and wat tha hell??
my dad is having mid life crisis i think... he told me that when i get the car registered he will fill up my petrol tank 4 times and give me $200 if he can drive it for 2 hours before me! (it would be different if i had my lisence but i get it like 5 days after i get it registered so i will make him drive it before i get my lisence...)
is this mid life crisis? recon he could be doing me favour.... giving me free fuel? bit more money for it? and also checking out if theres problems?
knowing my stooge of a dad he will be going out flogging crap outta it... and thinking hes kool pumping "rolling stones" with my sub =( *cryz*
I CANT WALK ON WATER BUT I CAN STUMBLE ON ALCOHOL
the VL has got all the power it needs and is already a handful for a new driver, especially the rear suspension which is not really capable of handling the normal power, be very careful about over accelerating when cornering
spend your money on premium quality tyres and maybe better quality shock absorbers at the rear
hmmm k... im driving a 3L umm... munro gt shockers i assumed were decent quality??
and tyres my dad got are 235each.... its was fairly expencive... like not low grade tyres... i cant actully remember if it was for 17's or 16's but yeh...
any idea's or the pod filter and then K&N
and also the performace chip... plz..
Well... I would stick with a standard panel filter instead of a pod. Pod filters suck hot air… and hot air isn’t good.
Go with a K&N panel filter and drill a hole in the bottom of the box and run some flexi pipe down to the front of the car (preferably where you have cool air intake) so that the air is even cooler and not being sucked in from the bay.
Also, yes… chips can be added to stock engines
As far as anything else goes for $200 I cant think of much. You say it’s a stock VL but is it turbo? If it is try throwing the waste gate to the dogs and buy yourself a blow off valve. Othersaround here know more then I do, so that’s it for me… hope this helped?
I have a question too! Can you guys recommend any particular brand of extractors and their rough price installed. Ill get them to install, I dont want to snap the bolts and be stuck. Also what does a chip package entail (any engine mods required) and what does one cost? Thanks
a popular brand of extractors are pacemakers and i think mine cost around $320 fitted.....as for a chip you can either get a change over system where you take you'rs in and they give you a computer back with a chip in it or you can install it you'rself......you can get a cam and chip package for around $600.....
how much extra do you get from the package? and what do you mean by cam?
camshaft. it changes the amount of time the valves are open to allow more air and fuel in and exhaust out.
If you want more inches, STROKE IT!
nice... $600 you say..... might look into that...
i would have to talk to somebody about your idea darkness i dont quite understand...
im not a reall genious with mah car let alone a academic at all to be honest..
umm...... yeh.. 'stock_vl' calais is what i own...
ooh and what kinda of increase can you can with extractors?? im assuming mine are as old as the hills etc... i need some sort of tidy up to this car..... i will get it looked at..
but yeah i seen and add on tv the other day that said that some 'brand' exhaust system give a 40% increase in cars performance:|
this possible??? anyways yeh... thanks heaps everybody!! good help so far!
i think u get 8-10% more power useing extractors and i have a air pod they do run hoter but i have seen some vl and vn whith them going out the frount just behind the bumper and the pipe that go from the air pod or fillter to the top or fillter put a 3" metal pipe i think u can get them from most car part shops so i have been told i like
sorry lost..... once again....Originally Posted by simbad
yous have got to be really simple for the simple minded.... lol. oohh gawd sorry.
ok.. so my air filter is the black box at the front passenger side. i put some kind of pipe from this out of the bottom of the car??
anybody actully gots a pic or wanna take one??
which is the most benefical in performance the K&N or POD??
i would assume the pod if it is hooked up where it can get cold air?? ....
I just rung up a few places and the best price for pacemaker headers to be installed is $500 and the next is $530. Seems to be a bit pricey, what do you guys reckon?
have a look at this thread....it got pics on a pod filter and a cold air sorta system....as for the extractors.....i recon you can get it cheaper if you look around....saw some on e-bay if you don't mind doing the work yourselfOriginally Posted by stock_vl
Perfomance Mods?
Boonie, dont ever pay full price, get them from a wrecker. Plolly cost $1-120 to install.
