Results 1 to 4 of 4
Thread: Air con/heater fan intermittent
    manualwagon is offline manualwagon
    Vl manual wagon, VS Statesman, 2007 Triumph Tiger.
    Jan 2007
    Mooroopna Vic
    Default Air con/heater fan intermittent
    The aircon/heater fan operates intermittently on my wagon. I.ve changed the switch block over and it worked Ok for a short time, then started doing it again. What is the most likely, Fan switch on the control block or the resistors ?
    Road trawling paddock bomb = moody VL
    Jul 2009
    goldfields VIC
    does it work if you move the switches around a little bit like move the temp or direction switch up/down ever so slightly?
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    because it is an old slide type variable resistor with 2 rails and ball bearings/springs/contacts the rails become warn as well as the contacts and balls see if u can get a newer switch block or use an alternative
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    as above, And the fan speed switch are common problems, they are not the best of quaility.
    clean the slide control contacts also.
    Nobody wants to play with me
  1. Intermittent Horn
    By HamaTime™ in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-05-2009, 11:08 PM
  2. VR - intermittent missing
    By woj in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-04-2008, 02:23 PM
  3. intermittent indicators
    By bassmansimon in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-02-2007, 07:55 AM
  4. Intermittent Air Con VN
    By Elvis-in-OZ in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-01-2007, 09:14 PM
  5. Intermittent A/C, HRW, Hazards
    By Dogsbreath in forum Electrical Wiring / Questions
    Last Post: 12-12-2006, 11:22 AM
