Results 1 to 10 of 10
Thread: steering question
    vl berlina wagon 6cyl
    Jul 2005
    Default steering question
    under my VL steering rack is a length of black plastic tube that over the years had shrunk, causing 1 end to come away from its connector, I replaced it with a length of new tube
    what does this tube do? does it equalise air pressure for the power steering, in some way nothing was leaking from it and it isnt mentioned in elleries VL manual
    do all VL berlinas have power steering as standard?
    VS executive
    Jan 2005
    berlinas a have power steering some vls didnt have it. maybe 86 models dont.
    Half a carton and still going!!! Now thats Economy
    vlv8vic's Avatar
    vlv8vic is offline <---Brad Quaid = internet stalker
    M5
    Mar 2005
    Australia
    yeah it just equalises the pressue between the two boots on either end, its only air. they only reason tehy are sealed together was to keep dust and dirt out. not saying your rack will shit itself or anything but dont be shocked if it does eventually (most have or are around now...) when it does looking at about $400 change over. like i said yours might still have 10 years left in it if your lucky so dont despair!
    (my old one had the plugs for the tubes snapped off....)
    VL RB30 Berlina
    Nov 2003
    all the vl's except the sl's had power steering.....the sl's didn't have air-con either....
    vlv8vic's Avatar
    M5
    Mar 2005
    Australia
    VS executive
    Jan 2005
    do you actually want an answer to that...
    vlv8vic's Avatar
    M5
    Mar 2005
    Australia
    Jul 2005
    this plastic tube and plugs seems likely to be damaged if any bushbashing is done with a VL as its down low and at the front
    vlv8vic's Avatar
    M5
    Mar 2005
    Australia
    true but even everyday driving will do it. mine was certainly never 'bushbashed' its either plastic or rubber hose and heat, water, wear and tear shrinks and damages it. jobs right!
    vkberlina's Avatar
    vkberlina is online now VK Madman
    Mar 2004
    NSW Central Coast
    Something you might want to do is see if a tube of a VK power steer rack will fit as they are metal, if not I would go to somewhere like a brake place and see if they can bend up a piece of tube to suit for you.
    cheers
    Scott
  1. VC power steering question?
    By Drewie in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 31-08-2007, 06:54 PM
  2. Steering Boss Question
    By pvcerod in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-03-2007, 04:52 AM
  3. steering question
    By Snotty in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-05-2006, 08:24 PM
  4. Question About Ignitions and Steering Locks
    By azzfox in forum Electrical Wiring / Questions
    Last Post: 07-03-2006, 10:33 PM
  5. Power steering question.
    By Flange in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-11-2005, 10:39 PM
