Originally Posted by
detox_nath83
i will have 1 line in from engine bay,(vacuum) goes on outter pipe, now there is paper tabs on the hoses with numbers to match up the pipes on the plumbing disk but they have probably worn off. mine had
i just plugged in 1 at a time to find what controlled what as in if the demister flaps open when the slider is on feet move it to another pipe behind the unit till it corrosponds to the right setting
good luck can be annoying but hey its only like 6-7 pipes to play with
Goodluck
let us know
