Results 1 to 4 of 4
Thread: Chasing Part No. If possible
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    Default Chasing Part No. If possible
    Hey fellas i have sprung a leak in my L from my heater hose return line well the barb that comes off the block on drivers side right near the bottom radiator hose housing.(basically behind the impellar of where the pump sits right infront of the Engine mount). it also has a pipe off this piece that runs to plenum and through throttle body etc etc.
    i have taken a pic of my one from my spare RB30 but am looking at putting a new one in if i can source it.
    Thanks in advance
    Nath
    strgas's Avatar
    strgas is offline GRA = REAL HP
    Oct 2009
    good luck finding a new one , I replaced mine with a brass one i made on the lathe .
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    maybe i could slide over a sleeve and weld it on?? possibly
    or clean it up and use a better hose clamp as the one there is a shitty thin double wire type as i still have a bit to cllamp 2??
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    well fixed this problem but have come across another where i have a corroded out barb.. fixing tomorrow and all should be good
  1. Chasing 304 VK / VL engine
    By VYSSV8 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 22-05-2008, 08:12 AM
  2. chasing vr-vs parts
    By evl83h in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-03-2006, 08:13 PM
  3. Just chasing opinions
    By VN_circleworker in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-10-2005, 06:27 PM
