Results 1 to 3 of 3
Thread: engine miss
    VL RB30 Berlina
    Nov 2003
    Default engine miss
    before the weekend, i noticed a dead spot between 4000rpm and 5000rpm.....i let it go over the weekend and i drove it to work today and the dead spot turned int a bad miss(like i was hitting a rev limiter)also the tacho seems to jump around a lot whereas it has never done it before.....anyone got any ideas.....i think it's either a realy, bad fuel or something like that but i have to wait until the weekend to find out for sure...i hate winter....wake up in the dark, get home in the dark and can't work on my car
    VL Crapbox
    May 2005
    hmm, ignition would be under load mostly, i would start with fuel filter which is under rear of car near tank. Take it off and tip it up with fuel tank end facing groun\d, see if black crap comes out or really dark fuel but im talking chinks. Sounds like not enough fuel getting in me thinks but while ur at it, check fault codes on ECU.
    Search on here for fault codes if u dont know how.
    If you want more inches, STROKE IT!
    VL RB30 Berlina
    Nov 2003
    i fixed it....bon't know how exactly, but i removed all the sensor plugs and put them back on......probably dirty......investigate furher on the weekend i think!!!
  1. My vr has a miss?? need help??
    By Adz_3.8 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-02-2007, 09:18 PM
  2. Intermittent miss on VP V8 with engine light flickering
    By andynogo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-01-2007, 08:53 PM
  3. Near Miss???
    By JMiller in forum VY Holden Commodore (2002 - 2004)
    Last Post: 14-08-2006, 10:36 PM
  4. Engine Miss
    By Harvs82 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-07-2006, 09:21 PM
  5. Engine miss firing
    By AlpineRaven in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-05-2006, 03:29 AM
