Results 1 to 3 of 3
Thread: removing headlight
    vl berlina wagon 6cyl
    Jul 2005
    Default removing headlight
    seems you have to remove part of front bumper top trim to get at headlight bottom screws
    can this be done without removing front bumper bar?
    Jul 2005
    Default replacing bumper top trims
    can anything be used to replace the bumper bar top trims on front and rear, the original plastic ones usually fall apart due to sun damage and the VL looks untidy without them
    has anyone found a substitute?
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    it can be done if your not too worried about your paint and what not
    i use to remove only my top centre mould and grill before to get my lights out
    but now i take it off properly with my car,
    bar off first
    sides moulds
    grill then centre
    depends if your parinoid :P
    you can get aftermarket moulds, the TYC are a good make of non genuine stuff. just make sure your happy with the product before you get it painted
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
LinkBacks (?)
  1. help on removing a/c when removing engine
    By sebstenator in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-02-2008, 02:19 PM
  2. Removing Headlight switch from dash
    By Miss-E in forum VY Holden Commodore (2002 - 2004)
    Last Post: 04-10-2006, 12:25 PM
  3. Headlight switch removing/replacing
    By vt_hsv in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-06-2006, 07:26 PM
  4. Removing headlight protectors for cleaning
    By SecretSquirrel in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 13-05-2006, 11:37 PM
  5. Removing Dash Parker and Headlight Switch.. ?
    By Grommitt in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-04-2006, 01:31 AM
