+ Reply to Thread
Results 1 to 3 of 3
Thread: a few things
    vl berlina wagon 6cyl
    Jul 2005
    Default a few things
    the oil pressure gauge needle jumps all over the dial on my 6cyl, is it likely to be the gauge or the sender or both?
    it seems the calais has a low cooling system water level warning light, is it possible to install this in a berlina?
    how long does the computer generally last and can you tell if its gone into limp home mode?
    If the blinker switch wont self cancel, you probably dont need a new switch, there are 2 small springs in the switch and they eventually break, my holden dealer still had some in stock for $1.50 each
    VL Crapbox
    May 2005
    mate i think from memory if u short the oil gauge wire to the block it will read full voltage, id go for a new switch m8.
    not sure
    not sure
    if its not self cancelling, then u prolly need another, grab one from wrecker.
    If you want more inches, STROKE IT!
    Bax
    Bax is offline Projecting Bax Monaro Bax Monaro
    Nothing
    Jan 2004
    QLD
    If its reading maximum.. It sounds like the the cluster has been changed and its not wired up at all yet. It's just a matter of connecting a blue wire from the plenum to the sender on the block.
+ Reply to Thread
  1. Some Things About Getting Old
    By Darren in forum Jokes/Humour
    Last Post: 21-09-2009, 04:12 AM
  2. Few things for a VK (SA)
    By hotholdens.com in forum Parts And Other Items For Sale
    Last Post: 09-05-2006, 10:36 AM
  3. What to do with these things?
    By CLE in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-08-2005, 08:21 PM
  4. 2 things (DVD)
    By fisherjo in forum VL Holden Commodore (1986 - 1988)
    Last Post: 24-08-2005, 08:03 PM
