G'day i was wondering what both a stock Vl puts out at the WHEELS and what a stock Vl Turbo puts out at the WHEELS
Also what is the 0-100 km/h dash for both
Also what is the 1/4mile dash as well
What da heck,
also what are the main differences Engine wise between them (obviosly the turbo, cooler, manifolds, exhaust), but what about the heads, conrods, cams, diff, shafts etc
for the power....i only know the flywheel specs....the times i don't know....but the differences between the engines are that the turbo has a higher flow oil pump, more valve overlap on the cam, different pistons for compression ratio and different injectors....thats all i can think of at the moment...
