hey guys,just put a turbo on my standard rb30,really need to know what else to do so ican get some more out of it.its only boosting 5psi i think.
up the boost too about 9 psi and you should be sweet
what has it got???
cheers bro.its got a stage 3 turbo kit from snort performance in albury.
get a boost gauge
if only boosting 5psi could be your wastegate being too weak, so a boost controller installed to restrict the boost getting to wastegate and opening it prematurely, trial and error man goodluck
dont overboost it or u will be picking up pieces of your engine so be smart about it :P
yeah im running 12-13psi all day everyday on a stock motor, hasnt missed a beat
yeah i got aboost gauge.just wasnt to sure how much boost i could run without blowin it up.
cheers boys
yeah but have you got a boost controller
oh ok,no i dont think i do.looks like thatll be the nxt thing to do.
forgive my ingnorance im not very clued up with any of this.
how much was the kit? im pretty close to albury, didnt know they did them there.
Need some parts for my VH 253:
Green standard steering wheel...Green lower B-pillar covers.
Green sunglasses holder/lower dash bits...Air-con and assorted engine bay parts.
PM with any info.
sorry bro it was wodonga,and it cost 4124 aud with shipping but cost me a bit more with the exchange rate to send to nz.
1+ full custom s/steel stage 4 turbo manifold
1+50mm external wastegate
1+garret gt /40ts turbo charger
1+50mm bov
1+4inch s/steel air intake pipe
1+2inch s/steel screamer pipe for waste gate
1+front mount intercooler 600*300*76
1+4inch pod filter
3inch s/steel dump pipe with o2 sensor bung
fuel pres gauge
hi flow injectors,fuel pump.and fittings and lines
Sounds like a good setup. Next thing i would do is get a full 3" zorst with high flow cat, adjustable boost controller. Then take it to a dyno tuner and get them to up the boost and tune it safely. What type of ecu are you using? standard vlt ecu or n/a ecu?
1988 VL Berlina turbo 5 speed
http://forums.justcommodores.com.au/...ml#post1446411
1987 VL SL turbo 5 speed ~STOLEN~
http://forums.justcommodores.com.au/...ed-manual.html
its a stock ecu but theres a place here thats does upgraged ones.i should of come to this site sooner ive had nore info in 2 days than the last six months gotta love the ozzies for the goods when it comes to holdens.
Lol yehhhh if you want more info head to calaisturbo.com.au - Powered by vBulletin its vl/vl turbo site.
depends on say high flow injecotrs/turbo injectors the ecu needs to be upgraded as the pulse rate is different for the turbo injectors to the N/A
the ozzies hell yeah we are here ftw
we love it
Bah
Drunk again
ok well it sounded like you wasnt sure if you was running 5psi or not
im running 6psi ATM would the standard N/A run higher with no probs say 9-10psi... few km's on the old girl... Nackerz said it will be fine hope so bloke :P
yeah sorry to hijack this thread drunk again
your thoughts????
yeah thats prob what spring he has in his external wastegate...BUT an adjustable boost controller will fix that.
and if you want a cheap one, go this, its what i have and had no spiking problems at all.
Turbotech manual turbo boost controller- THE ORIGINAL! - eBay Turbo Parts, Performance Parts, Car Parts, Accessories, Cars, Bikes, Boats. (end time 08-Feb-10 21:24:33 AEDST)
hahaha bet me to it again ya shit head ahhaha lol
step ahead brother......
boost controller FTW that will fix your issues(not a cheap one)
so then ebay it is for turbo inj and ecu
the turbotech controller is simple as but they work great have one sitting here in front of me .autospeed magazine dyno tested them against 400 buck electronic boost controllers got good feedback on them
Yeh ive still got mine here lucky i didnt put it on the wagon
