Results 1 to 9 of 9
Thread: Fuel Smell
    redvl Guest
    Thumbs down Fuel Smell
    Hello everybody,
    When i drive my car whether its for 5 minutes or 3 hours, it has this smell.
    I stop and get out of my car and all you can smell is petrol, there's no leak and it runs fine, does anyone know what it could be?
    VL RB30 Berlina
    Nov 2003
    check you're fuel lines in the engine bay......they are probably old and weak......i had the same problem and it was a fuel line from the pressure regulator.....
    kunifa Guest
    there is a stone guard behind the right back wheel. it covers the pipe where the fuel cap is. behind this guard are breather hoses for the fuel tank. in my car they had perished and broken. I just mreplaced the hoses and it was fine. its easy to get to aswell. u may need to jack the car up at the back to get a bit more room in there and then you just hav to undo 3 screws
    redvl Guest
    =TUR7LE= Guest
    mate, u got cracked fuel lines...i got the same problem, pretty common with the older commies...wouldnt bother trying 2 replace the fuel lines as theres 2 many 2 pick and choose from...just put up with it...just a little hint, dont fill ur tank more then 3/4 of a tank and it should gradually go away...nothing 2 serious, wouldnt worry about it if i was u...more trouble then its worth
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    redvl Guest
    VZ Calais
    Aug 2005
    Mackay Qld
    check the fuel injectors.Avisual check is all that is needed. Look for wetting on the injector itsself,or wetting of the manifold. seems to be a problem.
    vl rb30's Avatar
    vl rb30 is offline vn v6
    vn
    Jul 2005
    mate i had the same fuel problem gave me a headache it cost me $16.00 4 the breather hoses and its a prick ov a job but its worth it
  1. i can smell fuel
    By KingCoMMoDore in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-12-2011, 11:50 AM
  2. Fuel Smell
    By XXFR in forum VY Holden Commodore (2002 - 2004)
    Last Post: 03-03-2008, 09:46 PM
  3. Fuel Smell
    By holdensupporter2005 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 05-03-2007, 12:17 PM
  4. Fuel Smell
    By Thomo in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-12-2006, 03:41 PM
  5. Fuel Smell Vt 5.0
    By Secki in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-10-2005, 11:06 PM
