Results 1 to 12 of 12
Thread: Vl 6 oil filter replace
    VH
    Sep 2008
    Default Vl 6 oil filter replace
    Whats the best way to get the oil filter off a VL six cylinder motor and replace with new filter to do oil change? Hard to get to and work on .cheers
    VL Berlina turbo, VL SL turbo ~STOLEN~
    Aug 2007
    Newcasstle
    Nackerz's Avatar
    Nackerz is offline Rollin
    2 n/a vl's 1 twin turbo vl vn ss vy sv8
    Jul 2009
    1988 Holden Vl Commy
    May 2009
    Wellington
    '92 VP Calais
    Jan 2010
    Newcastle
    Screwdriver always worked for me, changed mine the other day and it came off easy as with one hand. Just use some cardboard or something under it To channel the oil into a tray or it will run all over everything below it.
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    if u only do them up by hand(recommended) u will never have a problem getting em off.
    always make sure u have the rubber seal coming off with filter and not leaving it on block
    unless u wanna pour new oil straight through engine.
    and put some oil on new rubber seal on new filter with some oil on finger. so prevent this happening.
    calais24/7's Avatar
    calais24/7 is offline Mucca Mad Boys
    VS Calais II 5L, 98 rodeo v6
    Jul 2009
    And no mate imo its easiest to get them off going in from the top, it is a bit awkward but an oil filter remover tool always comes in handy
    vl berlina wagon 6cyl
    Jul 2005
    I think hand tightening isnt enough and you would risk oil being lost thru the rubber washer, I use a filter spanner that allows the handle to turn outward, the space around filter is very tight
    however you can buy a brand of filter from a big car parts place that still has the spanner reciever part on the end for a few dollars more, I cant remember the brand
    agree that you must make sure the old rubber ring isnt sticking to the block, and do put some oil on the new rubber ring as it has to turn against the block while being tightened
    helps to clean muck from the wire connector from the oil pressure sender thats nearby
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    FIRM hand tightening is more than enough for replacing the filter, as the rubber will expand when heated, I would not recommend using a filter tool to tighten it when replaced unless you are old and/or weak and/or frail! this will put you in the same position as the OP as he can't get the filter off and has felt the need to post here for assurance he is not going to stuff it all up.
    HAND TIGHTEN THE FILTER FIRMLY WHEN REPLACING! NO PROBLEMS.
    Nobody wants to play with me
    VL CALAIS TURBO (GLDJET),VS S2 CLUBSPORT,VN POS
    Oct 2009
    Do it from in the engine bay use and oil filter removal tool and skin ur knuckles.lol little tight if u have cruise and other gear especially turbo bitz.
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    turbo bits dont make a diff as thats on hot side of engine(unless aftermarket plenum like rajab).... reach down under intake runners and undo it
    only hand tighten does not need to be hell tight its easy i dont know why there is a thread on this is
    unscrewing and then screwing back on...
    Nice Jatsvl ....classic :P
    VH
    Sep 2008
    Hey all, thanks for info on oil filter removal,I thought I needed a filter wrench but it came off by hand was easier than I thought.Cheers
  1. What is this and how do I replace it?
    By wetwork65 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 02-12-2009, 10:53 AM
  2. Whats the best oil filter,fuel filter and air filter for v6 vp?
    By Timsgmh in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-10-2009, 07:56 PM
  3. How do I replace the fan
    By Radarboy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-06-2009, 09:02 PM
  4. pollen filter/air con filter
    By binghy in forum VY Holden Commodore (2002 - 2004)
    Last Post: 30-05-2009, 11:45 PM
  5. STandard AIr filter or K&N POD/FIlter
    By KDB1972VT in forum General
    Last Post: 29-07-2005, 11:16 AM
