Results 1 to 18 of 18
Thread: How many of you who replace their own Timing belt
    VL 86 RB30 Executive Auto
    Jun 2005
    South OZ Adelaide
    Arrow How many of you who replace their own Timing belt
    Hey guys as above, do you take off the rocker cover and back off the rocker shaft retaining bolts?? To get the correct belt tension...
    I was confused now I'm just not so sure!!
    RIP Peter (perfect) Brock....
    Nackerz's Avatar
    Nackerz is offline Rollin
    2 n/a vl's 1 twin turbo vl vn ss vy sv8
    Jul 2009
    Jun 2005
    South OZ Adelaide
    Quote Originally Posted by Nackerz View Post
    why would you want to do that for?
    if you read the gregorys manual is does not say anything about removing the rocker cover and these bolts you speak of
    It does in mine I'll check again lol
    Nackerz's Avatar
    Jul 2009
    Jun 2005
    South OZ Adelaide
    Quote Originally Posted by mag View Post
    Yep that's what is says or you won't get the correct tension on the belt
    86 VLCT/ 03 II VY SS Ute
    Aug 2007
    nah mate no need to do that. i think it says in there if you have pulled the whole lot apart to put the belt back on first then do up them bolts but you dont have to undo them to just do a timing belt.
    what book is it from ? one of the green holden ones?? what pg?
    trust me mate its not neede ive done 100s of these at work and 3 of my own
    Jun 2005
    South OZ Adelaide
    Page 45 section 5. TIMING BELT AND TENSION.
    Nackerz's Avatar
    Jul 2009
    Nackerz's Avatar
    Jul 2009
    Jun 2005
    South OZ Adelaide
    Quote Originally Posted by seans VL Calais View Post
    That's what I was hoping as the job just gets bigger if you have too...
    Jun 2005
    South OZ Adelaide
    yeah i know that but what part does it say i just had a look
    To install..page 44 on to page 45 (7) loosen blah blah "Note"
    Aug 2007
    just do the belt mate if anything to get the tention right before you put the belt on turn the crank a little anticlock wise about half a tooth then put the belt on (dont undo tentioner yet) and turn the crank back to its orig spot (line up with the mark) the cam should stay in the same spot but now you have a good tention on that side of the belt and then release the tentioner and it should be a good tention all round, then obviouslt do your 2 revolutions and make sure it all still lines up. hope that made sence. it works for me anyway, on all sorts of cars
    Jun 2005
    South OZ Adelaide
    Gregorys No.238
    Jun 2005
    South OZ Adelaide
    Yeah that made sense to me thanks
  15. #15
    woteva's Avatar
    woteva is offline NEED 4 SPEED
    VRII V6 Auto Wagon
    Jul 2005
    Adelaide S.A.
    I did a couple on my VL many years ago. I do remember that the harmonic balancer had to be removed.
    The first timing belt I did was soon after I got the VL. And the second time I did it was when the timing belt had to be removed to replace the water pump.
    http://woteva.tk/
    If it ain't broke... I can break it for you
  16. #16
    Jun 2005
    South OZ Adelaide
    Quote Originally Posted by woteva View Post
    Thanks bud got one sitting here ready
  17. #17
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    i have done this at least 7 times and didn't bother with the cam bolts and have not had a problem.
    I'm not sure as to why they put that in the gregory's.
    Nobody wants to play with me
  18. #18
    Jun 2005
    South OZ Adelaide
    Quote Originally Posted by jatsvl View Post
    Thanks and no me either, so some time this week I'll do it...
  1. vl timing belt?
    By starfire vc in forum VL Holden Commodore (1986 - 1988)
    Last Post: 22-06-2010, 09:06 AM
  2. Timing belt to Timing gear's ?????
    By MMH84D in forum VL Holden Commodore (1986 - 1988)
    Last Post: 18-08-2009, 11:28 PM
  3. Timing belt
    By Tontos in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 24-07-2009, 04:12 PM
  4. timing belt!!!
    By ImAHoon! in forum VL Holden Commodore (1986 - 1988)
    Last Post: 27-12-2008, 11:27 AM
  5. replace fan belt
    By creamy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-08-2008, 10:31 AM
