Results 1 to 11 of 11
Thread: oxy sensor confusion
    VL Wagon 5 Speed
    Sep 2009
    Default oxy sensor confusion
    hi guys, my car wasn't idling happily on lpg so my mechanic told me to get a new oxygen sensor. and long story short after much arguing, i bought it off him, and in the end it actually made no difference to engine running. even though the lpg's been tuned 'by 'ear' and is running fine, and petrol's running fine, how should i go about getting the signal from the oxygen sensor to the engine? there is no change when plugged in or not. should the car die if the sensor is not working/unplugged?
    any help would be tops! thx
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    if its an old style lpg setup it wont even use the O2 sensor when on gas only on petrol
    VL Wagon 5 Speed
    Sep 2009
    VL 86 RB30 Executive Auto
    Jun 2005
    South OZ Adelaide
    Quote Originally Posted by tombomb View Post
    yeh but should petrol not run or run rough then?
    It won't run ruff just eat all your fuel quick as it won't be able to measure the mixture..
    I was confused now I'm just not so sure!!
    RIP Peter (perfect) Brock....
    VL Wagon 5 Speed
    Sep 2009
    VL Wagon 5 Speed
    Sep 2009
    just tryin to bump this thread.. would any1 know how to rewire the oxy sensor to the computer? im pretty sure the signal is getting grounded but not 100%.
    thx fellas
    rusty91's Avatar
    rusty91 is offline dopespec
    vs 5spd
    Aug 2008
    adelaide
    u can grab a test light and put the alligator clips on the positive of ur battery and then put the probe on the earth wire of the o2 sensor and see if the wire is earther or u can chek the amount of resistance in the wire by grabbing a multimeter and set it on ohms and then one probe on the negative on ur battery adn the other on the grounded wire coming out of ur o2 sensor
    strgas's Avatar
    strgas is offline GRA = REAL HP
    Oct 2009
    define getting grounded ???
    I dont have my wiring diagrams at home tonight be can do tmw night .
    VL Wagon 5 Speed
    Sep 2009
    ah yeh cheers, i tried checking resistance, not 2 sure which color wire on the oxy adapter's which... thc 4 help so far
    strgas's Avatar
    Oct 2009
    In the body loom the violet wire is 12v supply the white is active or signal wire back to the ecm the black is ground and should have zero resistance to the engine block or the battery earth connection ,
    VL Wagon 5 Speed
    Sep 2009
    ah ok cheers, ill test it tomorrow and let ya know, im just assuming the active wire is shorting somehow to the shield. coz the manual says there should be continuity between terminal 24 on the 16 pin connector and the active wire, which there was. but also said there should be NO continuity between terminal 24 on the 16 pin connector and earth. there was the same resistance between both tests. enlighten? aha
    cheers!
  1. gearbox confusion
    By buster1192 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-01-2010, 05:33 PM
  2. Confusion :(
    By Buggy in forum General
    Last Post: 14-10-2009, 05:56 PM
  3. RB30e ECU confusion
    By Krullos in forum Straight 6 Development And Modification
    Last Post: 28-08-2009, 10:34 AM
  4. Vy/vz Ute Confusion
    By vsbakkie in forum VY Holden Commodore (2002 - 2004)
    Last Post: 06-12-2005, 01:25 AM
