Results 1 to 10 of 10
Thread: Replacing thermostat, help please.
    VL 5 speed (sold), VS wagon
    Apr 2009
    south oz.
    Default Replacing thermostat, help please.
    Yesterday me and some mates were a bit outta town driving, then suddenly a fkload of steam and water was coming out from under the bonnet. Pulled over and when it stopped pissing water all over the ground opened the bonnet and had blown a radiator hose. Even before that happened it seemed to have run alot warmer than most VLs ive been in (around the half way mark most of the time) And i have been told by a few people that when i flush it out and put new hoses in that i should also replace the thermostat as i dont think it would have been replaced for a LONG time. Is there much involved in replacing it? Does the water pump have to be removed to take it out? Does anybody know what it involves? Cheers.
    vy2 clubsport
    Feb 2008
    adelaide
    thermo stat is easy no where near water pump.its in the housing where your top radiator hose goes into motor.
    oh and by the way vl's are supposed to run 1/2 temp
    Apr 2009
    south oz.
    Quote Originally Posted by bow down View Post
    alright thanks mate, just thought they usually run at 1/4 as most VLs ive been in do.
    Nackerz's Avatar
    Nackerz is offline Rollin
    2 n/a vl's 1 twin turbo vl vn ss vy sv8
    Jul 2009
    VP Executive S2, VL 5sp Berlina Wagon
    May 2008
    Down South, Adelaide
    yeah mine runs about 1/4 maybe a little warmer, 83c apparently
    Sleeper Wagon - In the Build
    VP Executive series 2
    Check out My Ride
    Current Mods
    Widened S/C CAI, 2.5" exhaust, Advance headers, no bellmouth, 17" VY SS, Foamy Tune
    Future Mods
    New Car
    Wanted
    MONEY!!!
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    vl thermostat is bottom hose not top like previously suggested and other engines. it is very easy to replace nothing major just make sure all surfaces are clean before replacing.
    my vl runs 1/8 of the temp and about 1/3 with the air con on it will go as much as 1/2 on 39+ degree days with aircon.
    I found with the vl the flakey rust builds up on the water pump shaft and impellor restricting water flow.
    also the engine fan (which is clutch driven) fail and not operate as it should.
    Nobody wants to play with me
    Nackerz's Avatar
    Jul 2009
    vy2 clubsport
    Feb 2008
    adelaide
    no he ment me lol i was in that state of mind first thing today bad night.
    Nackerz's Avatar
    Jul 2009
    vl berlina wagon 6cyl
    Jul 2005
    a new thermostat gasket will be needed and the type that sticks to one surface makes the job easier
    thermostats are cheap and dont last for ever
    you probably should replace all the other cooling system hoses
  1. Replacing oil switch (ebay one) and replacing cup holders???
    By BlackCaprice in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 27-06-2009, 03:50 PM
  2. thermostat
    By shakey in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 26-04-2009, 08:09 PM
  3. VX V6 Thermostat
    By Promotec in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-03-2009, 05:54 PM
  4. Which way does the thermostat go? + highflow thermostat?
    By thek in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-02-2009, 11:11 AM
  5. VT V6 thermostat
    By savage1987 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-05-2008, 02:07 PM
