Results 1 to 17 of 17
Thread: Remove rear window regulators
    VL SL Project / VN Formula 5Spd
    Jul 2009
    Young NSW
    Exclamation Remove rear window regulators
    My VL i had for a while now is near rego, and both rear window winders are like burred over and cant put a winder on to wind up or down . I have new track and gear to replace them with. Is it just taking the window out and drilling the rivets and replaceing it, and would using bolts or somthing to hold the gear on the door.
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    is the spline for the window good or is it just a stripped handle??
    the spline is a stronger material (metal) apposed to the plastic winder..
    weird why the spline would be stripped.
    if the spline is stripped at the window u will need to replace the spline shaft to gear..(complete unit??)
    let us know.
    cheers
    nath
    Jul 2009
    Young NSW
    Thanks for your quick reply its metal part thats stripped, i dont know how my mate done it buts its farrked lol.
    I have the gear and track thing to go in but just need some help on getting the old one out without breaking the window
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    forgotten how they are braced man. last time i had my rear door card off i was putting in cenral locking and cant remember how the setup is for the window.
    does it have nylon clips(attached to window) that slide along the steel guide channel which is mounted to the gear track..and cables for window raise and lower
    if so u need to angle the window in a way to slide the nylon runners out of the guide track, try different heights with the window to find where it is the closest to the end of the guide track(u channel)
    i remember on Vn commo(step dads) i fixed drivers window one of the clips dropped out of the guide channel and dropped the window on an angle was tricky but got it
    goodluck man
    Jul 2009
    Young NSW
    Included some pics of how bad it is lol. I wanna get the window out before i start drilling anywear lol.
    Attached Thumbnails Attached Thumbnails Remove rear window regulators-mikeys-pics-058-.jpg   Remove rear window regulators-mikeys-pics-059-.jpg   Remove rear window regulators-mikeys-pics-060-.jpg   Remove rear window regulators-mikeys-pics-061-.jpg
    MY 8.5 Calais V 6.0L, 88 VL Calais Turbo
    Jan 2006
    3 or 4 rivets to take the mech out, but take the glass bit out first by winding all the way down and take off the brackets that clamp onto the cables. Then remove glass and drill rivets out
    Jul 2009
    Young NSW
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    it doesn't look right, like it's been recessed back in to the door skin , it should be poking out way more than it is! you need to get behind it and try and somehow push it back out if you can.
    and does it have electric windows? what are all those wires?
    also why does one have 3 rivets and the other has 2 rivets and a screw?
    and it looks like the handles had been glued on for sale. wtf.
    Nobody wants to play with me
    woteva's Avatar
    woteva is offline NEED 4 SPEED
    VRII V6 Auto Wagon
    Jul 2005
    Adelaide S.A.
    It looks like it's snapped off ?? or something isn't right.
    I remember when I had my VL, the rear windows were very stiff. The window mech used a wire cable with small wheels fixed to the lower inside of the door that had seized. A bit of wd40 and grease got them moving again.
    http://woteva.tk/
    If it ain't broke... I can break it for you
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    jatsvl's Avatar
    vl exec wagon
    Nov 2006
    good call nath, hence the scrape marks on the paint work, maybe hacksaw.
    Jul 2009
    Young NSW
    Thanks for your help guys ill check it out today , it dosent have power windows switches in it so how would i find out what them wires are for in the window?? and if they are spose to be for power windows where should the wire up to ??
    Jul 2009
    Young NSW
    The wires are for a after market central locking kit. Im so totally thinking too just buy 2 rear vl doors , only bad thing is i cant get any in my paint :-(
  15. #15
    VL CALAIS TURBO
    Feb 2010
    hey wondering if you fixed? it or figured out the problem? i have a problem simular except i got all the parts i dont know hot to install it any diagrams that use could help me with please would be great ?
  16. #16
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
  17. #17
    Jul 2009
    Young NSW
    Sorry for the long time to add but i have worked most of it out.ill be putting picutres and help for others in this situation sometime 2moroz
  1. F&*(&n window regulators
    By slayer in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-01-2007, 05:30 AM
  2. Remove and Install Rear Window
    By VN_WA in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-05-2006, 07:04 PM
  3. VK Window Regulators
    By Rossco in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 08-03-2006, 09:50 AM
  4. Remove and reseal rear 1/4 window - How to ?
    By DJ Ice in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-02-2006, 12:29 PM
  5. How To Remove Rear 1/4 Window.
    By garfa in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-09-2005, 12:50 PM
