Results 1 to 18 of 18
Thread: turb conversion? how hard
    vz ss
    Sep 2009
    Perth SOR
    Default turb conversion? how hard
    thinking of turbing a vl when i pick it up[ from a mate? not sure what year it is. just wondering how hard is it to turb it if the block has the oil and water holes(if u get my drift)?
    wot parts are needed?(besides the obvious)
    Nackerz's Avatar
    Nackerz is offline Rollin
    2 n/a vl's 1 twin turbo vl vn ss vy sv8
    Jul 2009
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    man its quite easy if u do it properly as in not massive boost and blow your motor first run
    i have just done one at christmas time on my VL
    if it is a series 2 block yes u will have the provisions for oil and water feeds to the turbo and oil return on the exhaust side of the block.
    for water return u simply plumb into the return heater hose on intake side at firewall.
    depending on the turbo u want u may only need oil lines, this is what i have done i have a TO4E which is only journal bearing (oil) turbo which does not require water as well for cooling. see pics below in my signiture.
    a list of things man
    Turbo with (internal Wastegate) depends on turbo may need External Wastegate if does not have one attached
    Turbo manifold and dump pipe to cat(can be made up after dump pipe that is)
    oil/water lines (pirtek/Enzed) and are expensive.
    intercooler and piping (recommended for high compression setup to stop pinging/detonation, but its all in the tune if not, mine is intercooled and timing is factory at 15 degrees No pinging.
    Go new Plugs just the bcpr6es11 they are stock turbo plugs as well as N/A
    Turbo ECU and Injectors(recommended as N/A max out at approx 7psi)but i have used stock ecu and injectors running 6 psi atm with no probs.
    boost gauge.
    new manifold gasket for turbo manifold and gaskets for turbo
    can put new manifold studs in.(i didnt)
    Man its not really that dawnting and quite an easy process.. can be hard in places to get spanners and so forth but thats working on cars for ya.
    Do it smart and properly and it will last.
    Is this car Manual??
    how many Km's on clock?
    Give us a rundown and other members will help you through as well
    Goodluck
    Have fun
    calais24/7's Avatar
    calais24/7 is offline Mucca Mad Boys
    VS Calais II 5L, 98 rodeo v6
    Jul 2009
    Calais turbo is also your best bet for vl turbo advice, although there is nothing wrong with any vl blokes on here, there are a lot more over there to offer advice and help
    vz ss
    Sep 2009
    Perth SOR
    na its auto but i hav a donor car with a 5 spd in it. the motor has done about 250 thou kms, not sure on exact yet. has a mint boby tho wit a custom paint job.cant complain for a $50 unregod car tho. im not lookin for mass boost prob 7psi wud do for now. always wanted a vlt. they go hard stock, so turbed will be a bit of fun in the wet. thanks guys
    Nackerz's Avatar
    Jul 2009
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    high comp setup = more torque as well
    to have same booost as turbo Vl A8 motor would be less on high comp motor yeah meaning say 7 psi is equal to approx 10-12 psi on turbo motor??
    thats what i thought
    Nackerz's Avatar
    Jul 2009
    VL Berlina turbo, VL SL turbo ~STOLEN~
    Aug 2007
    Newcasstle
    VL Wagon 5 Speed
    Sep 2009
    is there a way of doing this without the water/oil lines from the block? eg i have a series 1 engine.
    apparently some joints do the whole conversion for under 2,000. would i have to pay more for them to tap water and oil feeds?
    vz ss
    Sep 2009
    Perth SOR
    Quote Originally Posted by tombomb View Post
    hey bro do u mind starting yr own thread?
    VL Wagon 5 Speed
    Sep 2009
    sorry man just seems uve been answered. perhaps my input will spark a huge discussion, and my question is on topic
    Nackerz's Avatar
    Jul 2009
    2004 XR6T & 1990 VN dragcar project
    Jan 2010
    Bendigo, Victoria
    I would much rather his input here rather than starting his own topic.
    This has been covered so many times 'how much to turbo my fully sik vl'?
    I have the answer for everyone so this never comes up again: between $1 and $8000.
    Done, sorted, use the thread search.
  15. #15
    Aug 2007
    Newcasstle
    You can turbo the series 1 block but it would be pretty hard if youve never done this shit before.... oil feed from the oil pressure sender, oil drain into the sump, water feed from the thermostat and water return to heater hose.... Much easier to get a series 2 block.
  16. #16
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
  17. #17
    VL Wagon 5 Speed
    Sep 2009
    ah fantastic, yeh ill agree - t'has been covered a billion times, fantastic fellas
  18. #18
    VL CALAIS TURBO (GLDJET),VS S2 CLUBSPORT,VN POS
    Oct 2009
    Piece of piss just make sure u get a s2 vl or u wil need to get the s1 block milled out for bolts or drop a s2 motor in it.
  1. Installing hard top, hard lid or hard cover?
    By clapnrobem in forum General
    Last Post: 12-10-2011, 08:36 PM
  2. I know it's hard to believe...
    By one_and_only2004 in forum The Pub
    Last Post: 24-11-2008, 12:02 PM
  3. turb buick v6
    By steveabbott in forum General Discussion
    Last Post: 24-07-2008, 01:21 PM
  4. How Hard? (VS V6 to V8 conversion)
    By wadeson88 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-02-2007, 12:23 PM
  5. Vp manual conversion and vn auto conversion
    By gumbs in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-06-2005, 11:08 PM
