Results 1 to 9 of 9
Thread: VL wont start
    vlcalais11 Guest
    Default VL wont start
    Hey all i have a 86 VL calais turbo. Its been running real shit lately coffing under booost and such. I traced it to a cracked cap in the coil lead, i got a new set of top gun leads and plugs this fixed the problem at first then the plugs failed (they were old plugs) put my original ones back in and was running good. then the other day coming back home it started again coughing and pingging real bad under load felt like a spark problem. was still driving fine other than the coughing so i got home pulled off the dizzy and cleaned all the terminals inside with some sand paper and the end of the rotor button put it all back togeather sprayed some of the connections near the dizzy with crc. and now it wont start. ive checked the spark it has fuel pressure, when winding is will wind like a champ then all of a sudden is will just go ba and stop ya have to turn the key a few times to get over like a real big kinda lump then it will wind fast again bout 10 revolutions or so then ba comes to like this lump again, i took out the plugs thinking it might have hydralic lock but all was clear in there. Something weird when i turn the dissy to like mover the timing back and forth the fuel pump will like start then stop like its building pressure back up. Please any help would be great otherwise i might have to call a mobile electician to come and look.
    Thanks again
    Lars
    VL Crapbox
    May 2005
    so you definitely have spark yeah?
    Did you pull the dizzy out m8, check the firing order, if it sound like it wants to kick over and then it hits a wall, sound like incorrect firing order.
    If you want more inches, STROKE IT!
    VL 86 RB30 Executive Auto
    Jun 2005
    South OZ Adelaide
    How did you go?? crank sensor maybe or coil . post back if you find out..
    vlcalais11 Guest
    Hey yeah i checked the firing order its all good, is there anywhere to test the coil, crank angle sensor? there is spark i took off #1 lead and put a spare plug in and it was sparking while winding over.
    Lars
    vlcalais11 Guest
    Hey i traced it to the damn crank angle sensor. The stupid lube mobile mechanic said it was the power transistor, which it turned out was fine. So much for getting a so called expet to look at it.
    Lars
    VS executive
    Jan 2005
    how much did he charge you
    Half a carton and still going!!! Now thats Economy
    Jun 2005
    South OZ Adelaide
    Quote Originally Posted by vlcalais11
    Hey i traced it to the damn crank angle sensor. The stupid lube mobile mechanic said it was the ignition module, which it turned out was fine. So much for getting a so called expet to look at it.
    Lars
    hey if a VL wont start thats the 1st place i'd look, so good to be running again..
    vlcalais11 Guest
    He charged me 130 bucks to tell me something that was fine was stuffed, im onto them trying to get my money back.
    Lars
    LiamVK is offline Gronnie
    1988 vl series 200
    Oct 2007
    Box Hill North
    i know its a bit of the topic but could someone please help me with the firing order of a vl?
  1. VX wont start
    By _VX_S_ in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-02-2007, 02:50 PM
  2. VS V8 wont start
    By rus in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-07-2006, 11:39 PM
  3. It just wont start...
    By VL86Berlina in forum VL Holden Commodore (1986 - 1988)
    Last Post: 26-02-2006, 07:08 PM
  4. why wont it start???
    By only-holden in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-02-2006, 03:15 PM
  5. Help wont start
    By kasey375 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-05-2005, 05:16 AM
