Results 1 to 3 of 3
Thread: Chug Chug? or Car Miss Firing
    Sick Blue VL Guest
    Default Chug Chug? or Car Miss Firing
    Hey guys,
    I was at the lights the other night and it was runnign fine up until i hit the gas at the lights not heavy at all and then it sounded like it was chuging like a train or something
    it would still take off the same and everything but with the brake on and everything you could fell the car moving a bit like if someone was at the back pushing down on the boot a bit. Not much but you could still feel it. and you could also fell it in the t-bar auto?
    any ideas would be great thanks sorry i could not explain it any better.
    Simon
    vlrad Guest
    I'm new too - since joining about 2 weeks ago I have got one feedback from the more experienced members.
    In the mean time I have bought a VL to teach myself on.
    Simple test you need to do - something to rule out.
    Access computer. Turn screw anticlockwise.Start car.
    Run at 2000rpm. If your green led doesn't flash every 2 seconds then it is likely the oxygen sensor is crap. - This test is free. Let me know how you go.
    vlrad Guest
    My injectors were leaky - this was leting air in. My idle was increasing all by itself to about 1500. I had to find the air leak as adjusting the idle screw did work long term.
  1. Chug Chug Chug, On goes the VS (Starting Issue)
    By yyg998vsute in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-02-2007, 01:37 PM
  2. Help, misfire?fuel mix?...CHUG CHUG
    By PaYno_de in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-01-2007, 07:49 PM
  3. vr miss firing on take off
    By vrberlina5sdp in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-08-2006, 11:05 PM
  4. vp miss firing
    By commy92 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-04-2006, 09:19 PM
  5. chug chug..
    By Snowfox in forum VL Holden Commodore (1986 - 1988)
    Last Post: 04-06-2005, 03:31 PM
