Results 1 to 12 of 12
Thread: E10 fuel
    calais24/7's Avatar
    calais24/7 is offline Mucca Mad Boys
    VS Calais II 5L, 98 rodeo v6
    Jul 2009
    Default E10 fuel
    Just wondering if its safe to put that e10 shit into the vl, mines non turbo and its like the only thing all the servos sell in canberra nowadays. So yeah is it safe and will it affect it over time?
    cheers
    Ozzie's Avatar
    Ozzie is offline JCCC Warrnambool
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    calais24/7's Avatar
    Jul 2009
    VL Berlina turbo, VL SL turbo ~STOLEN~
    Aug 2007
    Newcasstle
    acientally put some e10 in a long time ago when it first came out... made my car run like shit. Now its premo 98 or nothing
    executive vt 5.0lt
    Feb 2005
    west suburbs
    Quote Originally Posted by VL_5SPEED View Post
    if you run e10 in your car it will stuff all the rubber seals ect in the fuel system dont use it
    VT SS S2 A4
    Aug 2005
    Dec 2009
    Quote Originally Posted by gungazza View Post
    Your wrong 10% ethanol won't damage the rubbers in your fuel system. There is plenty of info on the net about this. It's fine for a standard engine non turbo charged. 98 is a waste of money in a stock engine.
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    my 2 cents worth,
    my vl sedan I had ran no different with no problems at all on the e10 fuel,
    the vl wagon I drive now hates the sh!t and runs like there is water in the tank. it took me 3 wks to sort it out after I got the wagon.
    here in Adelaide it is 2cents cheaper (and on some days the same price) than unleaded, so stuff it the savings aren't worth the hassle just like the "save 4c per litre shopper dockets" what a waste of paper.
    I'm on the fence!
    Nobody wants to play with me
    Aug 2007
    Newcasstle
    My experience it made my N/A run poorly. Now i can run no less then 98 premo in my vlt.
    burnz's Avatar
    burnz is offline dah dut dut da dah
    2010 CRUZE Diesel
    Jun 2005
    springfield
    i went and baught e37 yesterday, a bit dear i thought..only700ml
    i think they call it rum.
    Research has shown that men usually sleep on the right side of the bed.
    Even in our sleep we happen to be right.
    Powered By Garrett
    Tree cutter's Avatar
    Tree cutter is offline Tree cutter
    VX Calais SuperchargedV6
    Apr 2006
    Mt Gambier SA
    I would be a good idea to have a fuel filter ready to change if you run E10 . It seems to loosen up any water or crap in your fuel tank which then blocks your fuel filter. Normally the first tank of E10 will get rid of all the crap in your tank so change the fuel filter then and all should be good.
    calais24/7's Avatar
    Jul 2009
    Cheers for all the advice and to be honest i think ill just play it on the safe side and find a close by servo that sells the normal unleaded
  1. blockage in fuel line - appears to be fuel pressure regulator??
    By ryan1980 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-08-2011, 06:23 PM
  2. cracking open fuel tank to change fuel pump?!
    By VS5spdV6uteowner in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-01-2009, 08:00 AM
  3. Fuel gauge stuffed? or engine just drinking fuel?
    By Noy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-12-2007, 05:51 PM
  4. fuel surge turning right? weird inst fuel readings
    By vkotis in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-10-2006, 12:00 PM
  5. fuel injected 5ltr motor setup for dual fuel
    By ma77es in forum Swap / Wanted to Buy / Trade
    Last Post: 28-05-2006, 07:03 PM
