Results 1 to 4 of 4
Thread: much carbon buildup in motor
    vl berlina wagon 6cyl
    Jul 2005
    Default much carbon buildup in motor
    does a stock standard RB30 motor get much of a buildup of carbon in the engine, so increasing the compression ratio and making higher octane unleaded fuels worthwile?
    mine runs happily on the lowest octane unleaded
    Jul 2005
    Default will earlier metal bumper bars fit a VL
    commodores had metal bumpers until the VK, VL original plastic bumpers are now weak and brittle, breaking easily
    non genuine plastic bumpers are available with the top trims but arent cheap
    has anyone ever put metal bumpers on a VL? will they fit? they would be cheaper from a wrecking yard
    Nackerz's Avatar
    Nackerz is offline Rollin
    2 n/a vl's 1 twin turbo vl vn ss vy sv8
    Jul 2009
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    carbon builds up inside the throttle body and can cause the engine to be sluggish and almost stall on LIGHT acceleration, removing the air inlet duct and opening the butterfly spray carby/injector cleaner and scrub inside with an old toothbrush rinse with carb/injector cleaner replace the duct start engine and it should be much better, alternatively you can remove the throttle body and thoroghly clean for best results.
    metal bumpers may fit but would look totally GAY! and possibly defectable, the plastic ones cover approx 10inches below the grill on the front and about the same on the rear metal ones would only cover approx 4-5inches
    Nobody wants to play with me
  1. v6 buildup q's
    By TorquemonsteR in forum V6 Development And Modification
    Last Post: 20-04-2006, 02:20 AM
  2. carbon buildup
    By pingin in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 11-02-2006, 03:19 PM
  3. Vk Buildup
    By clinker42 in forum General
    Last Post: 28-09-2005, 10:59 PM
  4. Sludge Buildup
    By daggett in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 27-06-2005, 10:26 PM
  5. Sludge Buildup
    By ChRiDDa in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-03-2004, 10:30 AM
