Page 1 of 2 12 LastLast
Results 1 to 25 of 36
Thread: bleed valve location for cooling system
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    Default bleed valve location for cooling system
    Hi all I have questions relating to the bleed valve on the head for the cooling system, Where is the bleed valve? ie- what number cylinder on the head? is it on the passenger side? and how does it come out or open?
    Thanks all I wanna refill my radiator without cracking the head.
    ========My Statesman 20's Mafless and 3.9's========
    rattattack1313 Guest
    Cool
    okay.....follow the top radiator hose to the top of the motor....see the screw with a nut on it??????fill radiator, and resevoir,then start motor...then turn it off...and check everrything is still full.....then start her again.....when it warms up a bit...you then turn the screw...and let all the air out....
    ucwepn's Avatar
    WH statesman 5.7
    May 2005
    Thanks bro will give it a go when she cools down (just been for a drive)
    executive vt 5.0lt
    Feb 2005
    west suburbs
    the proper way to do it ,is to fill radiator ,take off rubber hose that gos from the resevoir to the rad ,and tape it to the bonnet stand above moter hight 'put in a small funnel into hose , there are 2 bleed nuts ,thay should say 'do not open when hot',open the lower nut ,and pour water into funnell, when water starts to come out of bleed hole ,tighten it ,and then lossen the top nut , and pour in more water ,and then tighten when water comes out job done
    if you dont do it properly you will blow your head gasket :b:
    ucwepn's Avatar
    WH statesman 5.7
    May 2005
    VY Berlina Wagon
    Dec 2003
    VL Crapbox
    May 2005
    Dont forget the one at the top of the intake manifold.
    If you want more inches, STROKE IT!
    vl berlina wagon 6cyl
    Jul 2005
    you must undo both bleeder nuts, safer when cold, its easiest to force water into the radiator under pressure with a hose until water flows out of both holes
    if no hose the other idea with funnel sounds clever, an alternative is a long length of hose that just fits inside the radiator cap hole, to get the filling height above the higher bleeder screw on the top of the intake manifold. a spare top radiator hose seems suitable
    would be a good idea to carry a spanner for the bleeder screws and other gear if you are short of water in the middle of nowhere, otherwise it seems steam builds up at high pressure in the top area, stopping any water getting up there, resulting in the infamous steam trap and a cracked head thru overheating
    the nissan ebgine was shoehorned into the VL resulting in the top of the water jacket being higher than the top of the radiator
    vlrad Guest
    Just for a laugh - about 2 weeks ago I replace the inlet manifold with a second handy - I turned the ignition on I heard the fuel lines load up under pressure. I started the car checking for leaks of any kind. After about 5 minutes I was sitting in the car (bonnet off) I was looking at the top of the engine when a 4 foot high stream of fuild streamed into the air - I thought christ a fuel leak, its going everywhere - it was coolant streaming from the bleeder (which was sitting loose).
    vlrad Guest
    I sheard one of the bleeder bolts (the one near the temp sensor) - nasty old thing - anyone know what the treat specs are so I can run a tap in it to put a newie in.
    Jul 2005
    VL Crapbox
    May 2005
    just drill it out with a 3mm bit, i think the thread is only 5mm so centre punch it and drill straight, you shouldnt have to tap it. Pick up one from the wreckers, mine gave it to me. I tried others but you need to put a copper wacher there, cause it heats up you cant really use anything else.
    megee83 Guest
    Quote Originally Posted by harry3
    mechanic mate o mine reckoned to jus cut a bottle (like a 2L milko or similar), wrap some gaffa tap round it to seal against the fill point on the radiator, top it up with some coolant and run the motor til air works itself out... ive always done it like that an havent had any probs. mind you to be honest i wasnt even aware o the bleeder screws...
    is this gonna do the same job or do you think some air would still be left up in there?
    VP EXECUTIVE 3.8 V6 t700
    Jan 2005
    Armadale Perth
    Thumbs up
    Quote Originally Posted by ucwepn
    top radiator hose nipple at head, there is a 10mm bolt/phillipshead thats number one, number two on front of intake manifold/plenum at number one pipe/tunnel it a 10mm too, but do the lower one first, then fill coke bottle stick in radiator with 10mm open till water runs out put back in bolt while bottle still filling then tighten, take out top one to remove air pockets hotspots, and squeeze full two litre coke bottle till water comes out top one, keep squeezing while you put bolt back in, this way you have done both sides of a cold thermostat,
    reagards jimmy
  15. #15
    Jules86's Avatar
    Jules86 is offline The Cream Machine
    VL(VeryLow) Commodore Exec.
    Jun 2005
    Rockhampton
    this shit is confusing...i only got the one bleeder valve the one infront of the intake manifold, the other one is snapped off (was told i didn't need it) so if i was to get a hose and have sitting higher than this valve (even higher), and pour coolant into it until it started coming out of the top (valve), would this work? And does that bolt have to be completely taken out or just loosened?
    This should be able to be done while the car is off, or should the car be running while performing the methods above???
  16. #16
    Jules86's Avatar
    Jun 2005
    Rockhampton
    Well it might seem that they didn't use my bleeder valves when the head was replaced, cuz now i have no bleeder valves. It was as tight as all hell, but i undid it slow and it went SNAP! And i went "F**K!"
  17. #17
    Stewart1000's Avatar
    Stewart1000 is offline work done by ME
    VL twin turbo. VN5L. old jeep, shit mondeo.
    Sep 2005
    vic
    good investiment would be to build a pipe that sticks out of the top of the radiator and doesnt leak, and fill that up aswell because that makes it higher than rad and engine so it'll help get more air out!
    my web site
    stuff on the XF throttle body conversion, calais interior and lots of other junk!
  18. #18
    Bax
    Bax is offline Projecting
    Nothing
    Jan 2004
    QLD
    I've heard of people filling it through the overflow bottle. Highest part after all.
  19. #19
    executive vt 5.0lt
    Feb 2005
    west suburbs
    Quote Originally Posted by gungazza
    thats was already said
  20. #20
    Bax
    Nothing
    Jan 2004
    QLD
    My bad, I misread it.
    I just stick to the normal way, car on a hill so the radiator is the highest point in the car, take the bolts out, fill it until it comes out of the bottom bolt. Then do the top bolt. With the thermostat open preferably.
  21. #21
    VL 86 RB30 Executive Auto
    Jun 2005
    South OZ Adelaide
    Thumbs up bleeders
    Maybe a bit late but heres the location of both bleeders..
    Attached Thumbnails Attached Thumbnails bleed valve location for cooling system-bleeder-valve.jpg
    I was confused now I'm just not so sure!!
    RIP Peter (perfect) Brock....
  22. #22
    executive vt 5.0lt
    Feb 2005
    west suburbs
  23. #23
    executive vt 5.0lt
    Feb 2005
    west suburbs
    just follow this and you will have no probs
  24. #24
    bangers's Avatar
    bangers is offline <<<There's a good present
    EL FALCON XR6
    Aug 2005
    NSW
    you guys don't even need to use the bleed bolts. why risk snapping them. just undo the top hose into the manifold, use a coke bottle and hose and hold hold it higher than the head, pour water in and as the water comes through the manifold hose put it back on...easy.
  25. #25
    Bax
    Nothing
    Jan 2004
    QLD
    And you end up with an air lock. Seriously, if you do it that way you will end up with an air pocket still. It will always be there just because of the way its positioned.
  1. location of pcv valve
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 13-01-2007, 09:28 AM
  2. vacuum hose check valve location
    Last Post: 02-10-2006, 01:54 PM
  3. bleed valve
    By jippa3000 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-05-2006, 07:46 PM
  4. VR 5.0L coolant bleed valve
    By mess666 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-02-2006, 11:22 AM
  5. VT radiator bleed valve
    By Fiddler100 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-07-2005, 09:06 PM
