i have a RB30e and am thinking about putting DOC head on 3Lblock is this easy to do any recommendations on wat to use are welcome
the 25 goes on without much modification but the 26 head needs a lot of modifying
1988 VL Berlina turbo 5 speed
http://forums.justcommodores.com.au/...ml#post1446411
1987 VL SL turbo 5 speed ~STOLEN~
http://forums.justcommodores.com.au/...ed-manual.html
yes the rb25 water and oil galleries will line up with the rb30 and the rb26 head needs to be modified to fit and if you use the search function you would see that this conversion has been talked about before
ok boys, what would i need to do if i brought this motor to stick in my vl??
Just buy that motor that i was going to buy for 1500, heaps cheaper, i went a different way and have stayed with single cam check out my ride thread
