Results 1 to 9 of 9
Thread: VL Blowing Black Smoke
    VL Commodore
    Jul 2006
    Canberra, ACT
    Default VL Blowing Black Smoke
    Howdy VL Owners
    I am one. My VL is blowing black smoke and nothing my partner can do , can fix it.
    Month ago my injectors where leaking. My Man fixed that. (hated smelling the petrol)
    You drive and it wasn't idling right. Especially at the traffice lights. My verison is like if I had v8 Supercar!
    Replaced the Oxygen sensor. My AFM is roughly newish (ACA) Have used my bro's one .. No difference.
    My man was going to pull out my petrol tank today but read (oh I have printed many ideas to do)
    What did he say sucked out the return fuel line to the tank. No difference.
    At my wits end. So is my man!
    Does anyone else have an idea? I think it was last year replaced Fuel regulator.
    Only newish oil, plugs and leads.
    My back tail light is brown and I hate it, you can't remove it. Grrrr (Car is white!!)
    Love to have any ideas?
    Thanks if anyone can help. Much appreicated.
    Rachly
    Canberra, ACT
    vy2 clubsport
    Feb 2008
    adelaide
    Nackerz's Avatar
    Nackerz is offline Rollin
    2 n/a vl's 1 twin turbo vl vn ss vy sv8
    Jul 2009
    James39's Avatar
    James39 is offline Gave up on VL's
    1995 VS Acclaim & 1992 Holden Barina
    Jul 2009
    Newcastle NSW
    Might be bad injectors, try some good injector cleaner.
    And or disconect the battery for 5 mins, to reset the computer....
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    or stuck auxilary air control or idle air control valve, or a faulty coolant temperature sensor.
    Nobody wants to play with me
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    rich can also be a blocked air filter as well........
    or someone has stuffed with the screw setting on the AFM make sure it is set to factory..
    do a search for ohm/resistance setting not at home so i dont know off the top of my head
    Tree cutter's Avatar
    Tree cutter is offline Tree cutter
    VX Calais SuperchargedV6
    Apr 2006
    Mt Gambier SA
    Check engine temp sensor and check the vacuum hose that goes into your fuel pressure regulator. The vacuum hose can fall off or perish and crack so it leaks. If it leaks or falls off your fuel pressure will go up so you use more fuel.
    strgas's Avatar
    strgas is offline GRA = REAL HP
    Oct 2009
    Faulty ECT check for sensor output check ECM grounds , test for open circuit on ECT wiring and AFM
    vl berlina wagon 6cyl
    Jul 2005
    its possible that the fuel return line near the swirl pot is partly blocked, causing too high pressure in the fuel injection system
    as everyone says, black smoke means its running rich
  1. Vr :problem with car blowing out black smoke
    By mikapikapika in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-03-2008, 09:44 PM
